Thread: Higher TA value might due to the pH upon circulation
    Quote Originally Posted by Richard320
    pH looks low; but if TA is 80, it will likely rise some with circulation. Check it again a few hours after you've started things, and see what Pool Calculator says, or just post results and let us guide you.
    This article will walk you through things. Be sure you put the right pool surface and so on into the Pool Calculator.
    I don't mean to hijack, but I have a question for your Richard320.
    You say the pH will most likely rise due to circulation with a TA level of 80. Could I ask you what a higher TA value (say, 150) might due to the pH upon circulation? That's my situation--low pH, high TA. Going to do more aeration tonight with husband gets home from work with the sump-pump.
    TF50 test kit
    9800 gal.
    15x25 oval; AG
    Hayward sand filter with zeobrite; Hayward pump 1hp pro-max flow, or something like that, LOL!
    Southwest MO; hot/humid summers, full sun 8am-1pm, then shading begins.
    Feb 2008
    Denton, TX
    5,061
    Re: Higher TA value might due to the pH upon circulation
    The higher your TA, the faster your pH will rise with aeration.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    What he said.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by brownie16
    If your TA is high, then your pH shouldn't stay low or be dropping over time unless there is some acid source, such as using Trichlor pucks or even Dichlor as a source of chlorine.
    Thanks for the replies. I am using only bleach (now for the last 5 days; started with Trichlor and Dichlor 8 days ago) for chlorine, and am now aerating, so hoping that pH will increase soon.
    TF50 test kit
    9800 gal.
    15x25 oval; AG
