Thread: Just started the conversion to chlorine using bleach
    Mar 2011
    Hurricane, WV
    3
    I just started the conversion to chlorine using bleach. I tested for ph as noted in conversion process and ph was 7.5, then just added my first 420 ounces of chlorine bleach. Pool was clear on start. Noticed a slight green tint when bleach added. I have read about the changing colors, so just wondering what to expect next.
    Mhwhited
    13,500gal AG pool
    100# Haywoard Sand filter
    1HP 35GPM Pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Newbie switching from Baquacil to Chlorine
    Could be lots of colors and gunky stuff. Some conversions aren't that dramatic, but .........take pics!
    You're done SLAMing when:
