Results 1 to 8 of 8
Thread: Emerson 1 1/2 HP pump making noise...replace motor or pump?
    Aug 2010
    Atlanta, GA
    39
    My Emerson 1 1/2 HP is making noise. Sounds like someone else's issue and the research I've done is either bearings or something is going. In any case. I think I can replace the motor for $200-$300 if I hunt for a good price. However, it cost a TON to run last year (first year we've owned this house) and I'm eyeing the Hayward EcoPump that supposedly is 90% more effecient. That pump I think I can get for $1000. So I ask you, what would you do, is it worth it? How good is that ecopump? Also should I let the pump keep making noise? Pressure and everything seem just fine and there is no air in there, I've bled and checked numerous times (no air bubbles either to indicate a leak). Furthermore, it sounds different than air, it sounds mechanical, like it needs oil or something. Strangely, pressure is just fine.
    Attaching a picture of the pump. If you really want I can record the sound tomorrow if that helps.
    ANY HELP is appreciated. I really want to keep using this pool but $1000 is a lot of money for me to spend.
    40x20 Vinyl Inground (27,000 gal). SWG with Pentair 48 DE Filter.
    Also have a broken Polaris pump with no polaris and a broken AquaCal Heat Pump...inherited from last owner.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Emerson 1 1/2 HP pump making noise...replace motor or pu
    I think you could go with a 1 hp 2 speed pump, brand of your choice. Running the pump on low speed is fine for filtration and will save $ on energy costs.
    Love TFP? Become a
    TFP Supporter!
    Aug 2010
    Atlanta, GA
    39
    I've been researching for the last hour and think you're right. Do I need to replace bearings or are they part of the motor? Seems like a good time to replace if they are not. I'm looking here at the motors and the pricing seems good. http://www.poolcenter.com/motor_parts.htm
    This motor appears good
    B975 56J Frame - Two Speed Threaded Shaft Pool & Spa Pump Motor 1 230 2 $360.04
    Do I need to get an end cap with the two speed switch? Sounds like I might?
    30,400
    Have you decided to repair your pump or replace it with a two-speed to save electricity?
    Aug 2010
    Atlanta, GA
    39
    I'm not sure honestly. I don't think I need a 1 1/2 HP pump on this pool really seems like over kill. I think it's about 25,000 gallons, two skimmers two side returns and main drain, that's it. From what I read, maybe a WhisperFlo 3/4 would be better, not incredibly expensive and be a good balance.
    I read that to check if it's the bearings, take off the motor and run it and if it makes noise, then it's probably the bearings. Wouldn't I break the seals though on the pump by doing that? I'm also a bit hesitant to just replace stuff without knowing if that's the reason. I'll try to post a video of the noise, maybe someone can identify it or if you have ideas on troubleshooting, I'm all ears. I really don't want to spend more than I have to, but I really think this pump is oversized and costing a LOT to run. So I'd almost rather replace the pump entirely for about $400-500 than spend $300 just to replace the motor.
    Aug 2010
    Atlanta, GA
    39
    I went out this morning, it sounds REALLY bad, I turned it off, I don't want something breaking. It's making loud humming almost screeching sound and vibrating a little. Seems like bearings. I'm not sure how long my pool will go without the pump and filter (3-4 days???). I'm now leaning towards the whisperflo or something similar. Anything someone thinks I can find locally in Atlanta? Leslie's is a bit expensive but if it matters plus the WHisperFlo they sell isn't the EE one I see online.
    Sep 2009
    Greentown, IN
    914
    You might check around and see if there is a small engine repair center around that would be willing to replace the bearings for you... That's usually what goes out first I believe. Might be worth it to see... you could save it as a back up pump if you purchase a newer more efficient one.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Aug 2010
    Atlanta, GA
    39
    I did without much luck. I decided to get a 2-speed WhisperFlo which should arrive next week. This leaves me with 2 interesting questions
    1) How long can my pool go without a pump/filter?
    2) Since I'm going to replace it, I'm thinking about running the pump on Sunday anyway and if it breaks...so what, what's the worst that could happen? How good or bad of an idea is that?
    Tom
