Thread: Skimmer location
    Skimmer location
    We are having an above round pool installed in a little over a week and we are having an issue with skimmer/pump location.
    The people at the pool store tell us that the skimmer really needs to be in the northeast or northwest corner so the wind can assist with the skimming process. How much effect will this really have? Will we see a huge drop in performance if we located the skimmer/pump on the southwest corner instead?
    The reason this is an issue is that our current patio is on the northwest corner, and place it on the northeast corner would seriously impede the deck we are planning to build.
    Thanks in advance for the advice.
    Doughboy 18x38 AGP buried 2' deep. 18,400 gal. Hayward Power Flo Matrix. Hayward Pro Series High Rate Sand Filter. TF-100 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: Skimmer location
    If that's the way the wind blows, that's where it should be. It's very important. I could kill whoever set up my pool for the shortest pipe runs rather than the best spot!
    Just frame up the deck so you have a liftout section to access the skimmer. It'll only add a few bucks to the job, and will save you so much frustration you won't believe it.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    The best place for the skimmer is downwind, especially if you only have 1. If the skimmer is up wind, debris will always seem to float away from the skimmer and you will be spending a lot of time scooping it off the top by hand.
    Love TFP? Become a
    TFP Supporter!
    How far down on the wall is the skimmer usually placed. I would assume the water level can't be over the skimmer?
    Rebecca and Pat Loebach
    Peoria Illinois 61604
    tridoc927@yahoo.com
    http://www.renovatemyranch.blogspot.com
    http://www.embersgarden.blogspot.com
    http://www.drrebeccaknight.com
    Intex Ultra Frame 12x24 52" AG pool. 8,403 gallons
    Intex Krystal Clean Sand Filter Pump with 1,600 gallon per hour flow rate. Intex Krystal Clear Saltwater system.
    Dug 18 x 30 hole, 4' deep, put pool in hole and built retaining wall around it. Currently working on deck surround/topper.
