Results 1 to 13 of 13
Thread: Trying to get the water balanced
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    I am new to all this chemistry stuff, but I am determined to get it balanced. I did purchase the Taylor Complete FAS-DPD K-2006 kit.
    Here are the readings I got;
    CYA 30 ppm
    PH 8.0
    Calcium Hardness 420 ppm
    TA 150 ppm
    CC 0.40 ppm
    FC 0.35 ppm
    I'm thinking I need to add about 15 oz of Muriatic Acid to bring down the TA. I have read where some people suggest to aerate the water. I have spa jets in the steps would that help? What else do I need to do? BTW, you guys have been so helpful! I have directed many of my friends to come to this forum to help them with their pool needs.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Trying to get the water balanced
    Your pH is also too high. Use The Pool Calculator to determine how much MA you need to bring pH to 7.5, then worry about bring down the TA.
    If you are using a SWG for chlorine, then your CYA needs to be at 70 ppm, and your chlorine should be 3-5 ppm at all times. Look here for recommended levelsfor your pool.
    Love TFP? Become a
    TFP Supporter!
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Quote Originally Posted by zea3
    Thanks, I was close. It said to add 18 oz of MA. It also said direct sunlight and Aeration can affect the balance as well. Maybe I should turn the spa jets off? It has been very hot here with temps ranging in the middle 90s.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    PH needs to come down. FC needs to go up. TA will come down eventually, after many pH adjustments. Running the spa will speed up the process, so keep tabs on pH, like every day until you get used to things.
    Check CYA again tomorrow. By the way, most of us mix up the sample, take our reading, pour it back, mix some more, take a reading, and so on until we get the same reading 3X.
    If it really is 30, you probably ought to raise it some. You can do it with plain stabilizer or with dichlor shock powder. Pool Calculator can help determine the dosages.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    For a while now I have been able to keep the ph balanced. I had to pick up some prescriptions for my dog so I took some water sample to the pool store next to the vet. They tested it and said it was perfect just need to super chlorinate. Their readings were;
    Alkalinity 120 ppm
    pH 7.6
    Calcium Increaser 214
    Total chlorine 0.23
    Free Chlorine 0
    Chlorine Stablizer 50
    My Salt meter on the Aqua-rite read 3100
    I super chlorinated the pool back on May 24th for 24 hours. How long should I let it run this time, the same amount?
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quick comment - those FC/CC numbers from your first post are not correct with a k-2006 kit. If you used a 10 ml sample, you would multiple by .5. If you used a 25ml sample, multiply by .2. So, your FC might have been 3.5 (if you used 10ml sample and 7 drops). Not possible to get a reading of .35.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I would not recommend mixing between pool stores and your own testing, if you are using the k2006 or the TF100...you'll just confuse yourself in the end.
    Pool school tells you to raise FC with liquid chlorine and maintain levels with your SWG. On the other hand if you you'd rather listen to the pool store you'll unnecessarily tax your swg to raise FC.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Quote Originally Posted by aa62579
    That was what the local pool store said. I need to take a new sample and test it myself.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by Malibu07
    CYA 30 ppm
    PH 8.0
    TA 150 ppm
    CC 0.40 ppm
    FC 0.35 ppm
    ~~ Allison ~~
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    I just tested the FC and CC with my Taylor's K-2006. I used the 10 mL mark and followed the directions on the lid. I had to add 2 drops of the R-0871 dropwise until the water changed from pink to colorless.
    Then I added 5 drops of R-0003....turned pink then I added R-0871 to change it from pink to colorless again it was 2 drops. So that would be a reading of 1.0 ppm for both FC and CC....right?
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Correct.
    ~~ Allison ~~
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    See, just goes to prove that taking water samples to the pool store can be costly.
    According to the pool calculator, I need to add 91 oz. of 6% Bleach. Do I need to turn the Cell off and how long to let the pump run?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    With CC at 1, you should shock the pool.
