Results 1 to 10 of 10
Thread: No more Black Hoses!
    NE Ohio
    63
    Thanks to all of the great information on this forum I finally decided to switch to PVC Pipe today! I got all of the items at Lowe's for about $55.00.
    The pump and filter seem to operate more efficiently now too!
    Here are a couple pictures of the finished job!
    [attachment=0:2cka5afh]2011-06-02_15-47-46_64.jpg[/attachment:2cka5afh]
    [attachment=1:2cka5afh]2011-06-02_15-45-58_675.jpg[/attachment:2cka5afh]
    24" Round Above Ground 52" high
    Jacuzzi CFR 100 Platinum Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: No more Black Hoses!
    What the heck? Are those unions? What an amateur!
    No professional installer ever uses unions. His work is so perfect that no one will ever need to remove anything, dontcha know?
    NE Ohio
    63
    LOL!
    Those are unions. I only used them because I am in Ohio and I have to take everything in on the winter and I thought it wold be much easier to take apart!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Looks great!...the only flaw I could find (not that I was purposely looking for one...the work is much neater than mine ) is that you might have wanted that shut off valve between the skimmer and the union, vs at the pump. Removing the pump requires removing the valve, unless I'm not looking at the pic correctly?
    PS...I'm in love with my unions...they make life easy
    NE Ohio
    63
    There is actually a union at the valve as well. I can disconnect it at the valves and then at the Skimmer and the Inlet so that I have no chance of anyone running into the pipes during the winter!
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Quote Originally Posted by Richard320
    Richard just likes to yank people's chains around here. Since he is in Ca. he has no IDEA what tearing down and re-assembling the plumbing for a pool is like every year.
    He's a good guy, really!
    I am in NE Ohio, too and believe me, as soon as I can get my DH on board with the PVC, that is how we will be doing things.
    Your set up looks great, BTW.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by Jimh64
    Yup, I see that, which is OK for cleaning the pump basket, but if you undo the union at the valve to remove the pump for servicing, you'll need to manually plug the skimmer.
    NE Ohio
    63
    Oh ya, I see what you mean now,,, well hopefully I never have to service the motor until I close the pool for the season! LOL!
    Feb 2008
    Denton, TX
    5,061
    Not a PVC expert by any means, but that looks very nice and clean compared to the messes that I create with sch. 40. UGH!
    NE Ohio
    63
    Thanks!
