Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Sand Filters: Why so Uncommon in Central Fl?
    May 2011
    23
    Personally, I think its a big conspiracy among the equipment manufacturers. I believe that the reason sand filters are hardly EVER installed here is because they are so low maintenance. There's no stuff you have to regularly buy. You don't have to get new cartridges filters ever year. You don't have to get a replacement o-ring every 6 months because the POS stretched out. You don't have to get DE at the pool store all the time. You just backwash and get new sand (probably from home depot) every couple of years. Sand filters aren't profitable for them.
    In my experience most homeowners are pretty lazy and could care less what type of filter was installed as long as its easy to work on. Whats easier than turning a valve?
    What do you think TFP?
    (BTW I'm only referring to residential pools here. It seems that DE is the norm with sand being second in the commercial world.)
    Florida Pool Service Guy
    15k Kidney Diamond Brite
    Hayward C-1200 Cartridge Filter
    Sta-Rite Dura-Glass 1.5hp Pump
    Pentair Rainbow 320 Chlorinator
    Heliocol Solar Panels
    Vero Beach, FL
    462
    Re: Sand Filters: Why so Uncommon in Central Fl?
    Nope, I don't agree. I'm in central Florida and I specified cartridge. If you properly maintain it, you should be able to keep the same filter at least 3 years (this is my 3rd and it still looks and works great). Also, if you are careful and lube the o-ring, it should last many years.
    I grew up with a pool with a sand filter and the reasons I picked cartridge is because it has a smaller footprint, you'll never accidently get sand in the pool, and best of all, I'm not wasting lots of water and chemicals flushing it out.
    If there is any conspiracy, its with the pool builders who I'd argue put in the cheapest filter they can - since as you said, most pool owners don't know the difference. And I suspect that cartridge filters are the cheapest.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Aug 2007
    Eastern Canada
    54
    Just replaced my sand filter and original sand after 26 years. No maintenance has ever been done (except for backwashing, and replacing the pressure gauge when it rusts), and it was replaced only because the drain pipe on the bottom cracked, and no replacement could be found. Water has always been very clear. The only disadvantages I can see with a sand filter are larger size, and the need to jettison some water when backwashing every week or two. Here that is not a problem, as replacement water falls from the sky regularly, and I always have to remove, not add, water. Also, we have wells and a high water table, so water is free and plentiful, anyway. I could see that drier areas with expensive or restricted water could favor the other filter types, but here, there is really no other choice. The only cartridge filters I have ever seen in this area are for hot tubs or Intex pop-up pools, and I have never seen a DE filter on a residential pool here in Eastern Canada.
    Judging by the amount of watering I saw going on when I visited Disney World in Sept., you don't seem to have any water shortage there yet, so I would conclude that your conspiracy theory may have some validity, although I understand that Central Florida has suffered droughts in the past, so the reasons may be historical.
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Jul 2007
    Suwanee, GA
    528
    I have a cartridge filter and love it. I don't clean them but once a year in the spring and my pool is open year round. I'm on the 5th year with the original carts and they still look good.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    May 2011
    23
    Quote Originally Posted by crabboy
    I see you have the Jandy 340. That filter gives me nightmares .
    I remember having to clean a customers' filter who had one. I took off the air release and set it aside and proceeded to clean the filters. Once I was done and put everything together, I couldn't find the air release nut anywhere. After some profanity and lots of sweating in the FL sun, I decided to take it apart thinking that it might have fallen in. Sure enough, the air release nut dropped in the filter and was all the way in the bottom of it . I put everything apart again only to have the gasket not seated right causing the filter to leak. After a third attempt at putting together did everything work ok .
    Feb 2008
    Denton, TX
    5,061
    Sounds like it really wasn't the filter so much as it was the maintenance guy.
    Apr 2009
    Burlington, ON, Canada
    344
    Quote Originally Posted by lborne
    Sand filters are much cheaper than cartridge filters in my neck of the woods.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I have had both and prefer sand
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2011
    Sunny Central Florida
    91
    I am SO jealous. I clean my cartridge twice a week
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    gordyjamz's Avatar
    Aug 2007
    Illinois
    34
    From personal experience, replacing an o-ring on a cartridge filter is a lot easier, quicker, and cheaper than having to replace a gasket seal on a sand filter. Also, as stated earlier a cartridge element can last years. If you should need to replace one, again, a lot cheaper and easier than having to fix/replace a broken lateral. We inherited a sand filter and in the first year alone I had to replace 2 gasket seals, a lateral, and replace the sand. Cost me close to $200, not to mention the hours spent taking everything apart, and re-balancing the pool chemicals afterwards. I ditched the sand filter after that first year, and got a cartridge. In the five years since, we are only on our second element, and have had to replace a body o-ring on it. $60 for the element, $12 for the o-ring. And both took literally minutes to replace. Some have mentioned that you can't vacuum to waste with a cartridge filter, but I installed a pvc valve between the pump and filter alleviate that problem. The only regret I have about the cartridge purchase is not doing it sooner. The money I spent fixing the stupid sand filter could've gone towards the cartridge purchase
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    30,431
    Replacing seals on a sand OR cartridge is not a common practice and should have little impact on the NEVER ENDING debate of which type filter is best.
    My sand filter is 7 years old and I have never done anything but backwash it and replace a pressure gauge I left on it one winter. That doesn't mean sand is better, it means that we all tend to favor the type filter we currently own.
    Dec 2011
    Orlando, Fl
    18
    I have been working in the industry in Central Fla for awhile.
    I know Florida is a unique market with respect to swimming pools, (excepting so. Cal & AZ)
    due to high avg water temps, and long natural swim season.
    Basically, sand filters are the least fine variety of filter (adding Zeolite, or DE to a sand filter notwithstanding)
    So, they will leave more organic debris in the pool,
    which means more work to maintain.
    I believe that a sand filter precoated with DE or Zeo type filter media to be as effective as a cart or (maybe) DE, but that is just not that common.
    Oddly enough, EcoSmarte is the biggest proponent of sand filters with Zeo media.
    Also, algae is a given in Fl, and it takes much longer to clean up with sand.
    -B.
    18,000 gallon in ground, plaster
    340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    completed 6/29/12
    30,431
    Algae is prevented in a pool (and removed from) through the proper use of chlorine. The filter you choose should have no bearing on your ability to maintain algae-free water
    Dec 2011
    Orlando, Fl
    18
    I know I am (sort of) not welcome, in a hospitable way here, being a lifetime PS guy...
    But, I have been lurking here for over a year, before creating an acct & posting,
    and want to be gentle here, so as not to offend the powers that be here.
    That being said,
    If we leave more organic material in the water, we will need more sanitizer to offset that, no?
    I am of the impression that Filtration, Circulation, and Sanitization are the 3 points to clear water, and more or less of one will require more of the others.
    -B.
    completed 6/29/12
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Jetta,
    You're welcome here.
    Yes, more organics will create more chlorine demand. I'm not sure what your question is regarding the 3 points to clear water
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I'm not in Florida but when researching my pool buy I seriously considered a cartridge but came to the conclusion (I'm not implying right or wrong) that sand would be easier and more cost effective. I've never had a cartridge filter and I've only had my pool for 1 year - but my personal research led me to conclude that sand was what I wanted.
    I seem to recall some people here saying that good old sand has been around for decades and works just fine. After all the options and bells and whistles and upgrades (and COSTS) of a pool purchase I suspect I started thinking "just give me good old proven things that work".
    That said, if the pool I ultimately wanted (and bought) only came with a cartridge I still would have bought it.
    22,553
    If you think about it none of the filters remove organics from the water. They stay in the fluid path until you clean the filter so it's the Sanitizer that does the work in all cases. The sand filter might leave a minute amount more organics in the water after cleaning but that's only if you cleaned the cart or DE perfectly and even then it wouldn't be enough more to tell.
    Mar 2012
    12
    Trouble I see with sand filter is they only become a "polishing" filter Once they partly clogged. Depending what they are clogged with (organics) Your chlorine use will go up.
    I prefer some thing where frequent cleaning DOES NOT lower the nominal filtration too much, but hey everything works better dirty.
    Pool cleaning service for Coral springs and all of broward. wet world aquatics Using science to give your pool and aquarium the best year ever.
    30,431
    acd,
    Welcome to the forum. I am having trouble understanding your post. Could you clarify? Seems to me chlorine usage will be essentially identical regardless of the type filter. I also don't understand the "polishing" part.
  20. Back To Top    #20
    Mar 2012
    12
    What I mean is the nominal filtration level goes down the more clogged a filter gets
    When new lets say you filter 10 microns when clogged you filter 1. Random non scientific numbers just giving example
    With sand filter they tend to start out with a higher micron level while some cartridge can start at less then a micron ... Not normally seen in pool industry ...
    You can clean a cartridge filter more often with out having a large impact on performance while a sand filter you can not
    By more frequent cleaning you are removing the organic matter from the water before it continues to break down.
    Some times pool haze is cause by particulate and is why de filters "make the pool sparkle"
    Again not the biggest issue but it's the only advantage i see of a cartridge filter.
    To sum up it's the relationship between organic buildup and filtration capability and how often you can clean while maintaining high filtration.
