Thread: Average filter run time?
    Jul 2010
    Mobile, Alabama
    12
    I have a 16' x 32' x 8' vinyl pool. The pump has a 1 HP motor. I can't find GPM on the pump, just a model number.
    When I opened my pool this year, I superchlorinated it and had the water crystal clear for a few weeks. Then it rained. The water went partly green. I can still see the bottom, but there is a definite green color in the deep end. I have been running the pump about 5 hours per day, while maintaining the chlorine and ph at normal levels. I should mention that the chlorine went to 0 the morning after the rain, and I let it sit till that afternoon when I got home from work.
    Since I have been maintaining chlorine and ph after the rain, and still have green water, I am wondering if I am running the filter long enough each day. How long should I run it? Should I superchlorinate again, or just increase my filter run time?
    Any help would be greatly appreciated.
    16' x 32' in-ground pool, approx 24000 gallons, Hayward S244T sand filter, 1 HP pump, Vinyl liner
    Re: Average filter run time?
    Im still a newbie myself, but i'd say if you have any trace of green in your water at all, you should follow this:
    Defeating Algae
    I don't believe just running the filter will eliminate algae.
    Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
    16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
    Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
    Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
    Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Now I'm starting to sound like all the rest.......sigh....
    Can you post a full set of test results?
    The filter won't remove green. Only chlorine will do that, unless the green is copper, which is unlikely as it was clear before and rainwater doesn't add copper. You have the beginnings of an algae bloom. Nip it! Nip it in the bud!
    [center:28kpxqdj][/center:28kpxqdj]
    I'm willing to bet big money on it. You need to shock the pool. Shock is a process, not a product, by the way. It's a verb, not a noun. You need to kill algae faster than it can reproduce, and keep at it until you've killed it all. To do so requires a proper test kit, a whole lotta bleach, some patience, and these instructions.
    Jul 2010
    Mobile, Alabama
    12
    Would love to, but I don't have and can't afford a full test kit at this time. I am following your advice about shocking the pool (again), brushing the pool, and running the filter continuously. I've been here before, so I know I'll get there in a few days. However, my original question still stands. Once I get the algae under control, what should my average daily filter run time be? Would running it longer than I did have prevented the algae in the first place? I have been running it around 4-5 hours per day. Any help would be appreciated, and I thank you for the answers you were able to give based on limited info.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by mdavis
    There is no way for anyone to quote you a "perfect" run time. That is something that you have to experiment with in order to figure out. Ideally, you want the pool water to turn over at least once per day.
    As Richard sort of alluded to earlier, filters don't prevent algae. Chlorine does. Algae blooms because of a lack of proper chemistry.
    Until you get yourself a decent test kit, I am afraid that you will probably continue to have problems. Unless you know exactly what is going on in your water, you will really just be chasing your tail.
