Thread: Chlorine / CYA Chart
    Aug 2010
    MA
    173
    Any particular reason the chart for "SWG Pools" CYA range is limited to 60-90? I understand that this is the desired range, but I am in the midst of a new pool start-up and bringing CYA incrementally. Am I to assume FC = 4 is good for any level of CYA < 60?
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    22,548
    Re: Chlorine / CYA Chart
    That would be a good assumption. If you go with that you'll be in good shape.
    The Pool Calculator can calculate numbers for any CYA level. Entry your current CYA level in the Now column and read out the recommended levels in the blue Suggested FC Level section towards the bottom.
    Aug 2010
    MA
    173
    Perfect! Thanks
