Thread: opening questions
    opening questions
    I just opened my pool and im not sure what to add for what
    TH-100
    TC-0
    FC-0
    PH-6.5
    TA-0
    stabilizer-0
    When I went to the pool calculator it told me to add 160 oz of bleach, 50 oz of borax, 453 oz of baking soda, 457 oz of calcium chloride, and 103 oz of stabilizer. I have the bleach, borax, and baking soda, but what do i use for the calcium chloride and the stabilizer? Im trying to go the cheaper route this summer.
    I have a vinyl above ground pool with a sand filter and holds about 19,300 gal of water
    I live in south carolina, above ground pool, holds about 19300 gallons of water, sand filter
    Aug 2010
    Dallas, TX
    4,052
    Re: opening questions
    You do need to get that pH up. Once you have it in range, your next immediate action will be to get your FC up. Stabilizer needs to come up too.
    You don't need calcium with an above ground pool. Stabilizer is the CYA.
    I reserve the right to be corrected on this
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by marcynkami
    TH-100
    TC-0
    FC-0
    PH-6.5
    TA-0
    stabilizer-0
    To get the pH up I would use the Arm and Hammer super washing soda, it will raise your pH and TA which also needs to come up. when I opened my pH was 6.8 and TA ws 70. I used about 48 ounces of the Super Washing Soda and it came up almost immediately to 7.4 pH and 120 TA. Mix it in a bucket with very warm water so it dissolves thouroughly and then poor into skimmer.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by cubbybeave08
    +1
