Results 1 to 11 of 11
Thread: Sudden Drop in pressure. Help!
    Hi guys, Something really weird is going on.... I'm getting normal pressure, then sudden drop, then back up to normal, then back down and it stays there.
    Things I've done:
    Cleaned the skimmer line (only have one)
    Blew out (with air) the skimmer line from the pump. no problems that I can tell.
    Took off the motor at pump and checked for clogs, etc. Nothing...
    Motor is about 5 years old and when taking it off the unit and operating in open air, works fine.
    Any ideas?
    Thanks
    My lovely money pit = 1971 20x40 ft Concrete pool. 2008 Hayward SuperPump 1.25 HP. 2010 Hayward 244T Sand Filter. 2011 Skimmer (1) Returns (3) with 2011 plumbing in series. 2009 Rheem P-M336 Digital Gas Heater.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sudden Drop in pressure. Help!
    Watch the water in your skimmer. Any surging or vortex?
    Nope just a slow crappy suction.
    Nov 2010
    Calera, Al
    271
    It would be helpful to know what type of equipment you have. If you go into the user control panel and edit your signature to include your info, pool type, volume, equipment ect....
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Edited my signature! How's That?
    Nov 2010
    Calera, Al
    271
    Excellent! Most helpful, Have you backwashed? Is your filter pressure high as compared to normal?
    ya I tried to backwash it however the pressure is too low to do anything...
    I checked the skimmer line with a DRAIN KING. Water comes through no problem.
    Also, it gets to normal operating PSI then drops.... builds up again... then drops...
    really weird.
    22,548
    Is there air in the pump strainer basket when it's running? If so remove and clean the strainer basket o-ring and lube it good before putting it back. Check it for nicks or cuts while you have it out.
    Think I know what it is... stay tuned...
    Mar 2007
    Coastalish 'down easter'
    4,160
    This won't fix any problem but it will eliminate the filter - how does the pool run when you put the multiport on 'recirc'?
    Luv& Luk
    -Ted
    I'm having this problem right now after having just replaced the pump motor. Investigating now, but if you did find an answer, I'd love to know.
