Hello,
You guys helped me last year so I figured I would pick your brain again.
2 years ago I bought a mother load of 3 inch pucks. Last year, I began using the bleach method. The problem now is that I have a huge tub of pucks sitting in the pool shed. As you guys know, these are expensive. I'm aware that the pucks can/will raise CYA levels. My CYA is currently at about 45 (after dumping some stabilizer in a week ago).
My question is this: If I use a puck every couple days in the pool, will I significantly raise my CYA level? to the point where I will need way too much bleach to shock the pool? I'm trying to understand how much CYA each puck will really increase my pool by.
