Thread: Anyone have this happen? Polaris Wall Collar problem
    May 2011
    Herndon, VA
    6
    The 2 pins in the wall collar for the Polaris quick disconnect sheared off. I can no longer hook up my Polaris to the wall jet. It hooked up fine yesterday and then today I came out turned on the booster pump and the hose halfway popped out.
    I'm going to buy a new wall collar and install it but has anyone ever had this happen? Is it pretty common for them to wear out or did I hook something up incorrectly?
    Thanks
    My Goal is Crystal Clear....
    18,000 Gal, IG, plaster, attached spa
    Jandy Sand Filter with Zeolite
    Polaris Pool cleaner
    1.5 HP pump with Polaris booster pump
    Aug 2007
    near the swamp
    806
    Re: Anyone have this happen? Polaris Wall Collar problem
    pretty common
    Mine sheared off inside the wall. I had to use a small vibrating saw to cut it out....very carfully so not to damage the threads on the pool side of the connector.
    in ground plaster kidney ~15500 gal, Pentair Clean & Clear Plus 240, Whisper Flow 3/4hp, dedicated pool cleaner w/booster pump mod# PB4, pool - 20+ yrs, pump, filter and booster ~9 yrs, Polaris 380 pool sweep(~15 yo).
    Aug 2007
    near the swamp
    806
    a putty knife or fan blade wide enough to fit in will help you unscrew it
