Results 1 to 8 of 8
Thread: Flow meter location
    May 2011
    Los Angeles, CA
    228
    Flow meter location
    Hi all,
    Thinking of installing a flow meter in the pool plumbing... Is there any difference if i install it right after the pump before the filter or if i install it after the filter and heater just before the 3 way valve on the return pipe?
    Thanks in advance!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    22,549
    Re: Flow meter location
    It doesn't really matter as long as you respect the upstream/downstream requirements of the meter you use.
    May 2011
    Los Angeles, CA
    228
    Thanks!
    Jun 2011
    NW Florida
    57
    My reply is probably much too late for the original poster, but perhaps it will benefit someone. Our flow meter was installed before the filters, and got stuck repeatedly. So I moved it to a position after the filters, and have had no problems.
    Mike
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Diver's Avatar
    May 2011
    South of Boston
    450
    Mike,
    What kind did you install?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Jun 2011
    NW Florida
    57
    Hi Diver,
    It was pre-existing. I just moved it downstream of the filters.
    http://www.bluwhite.com/Products/Var...f300_photo.htm
    Mike
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by salvationarmy
    Hi Diver,
    Mike
    Mike, any problems with it leaking at all? i wonder how it reduced the flow itself ...
    Jun 2011
    NW Florida
    57
    Hi Diver-
    No real problems with it leaking. It did not reduce the flow, it just did not register any flow at all after it apparently got clogged with debri on the dirty side, upstream of the filters.
