Results 1 to 11 of 11
Thread: Question about CYA
    Question about CYA
    So I have read in many different areas on here that CYA is never used up... the only way to get rid of it is to drain the pool or reverse osmosis.
    I am wondering then how my CYA has gone from 68 to 16 in the past week. All I have done is shock the pool to kill algae.
    Any ideas?
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    Aug 2010
    Dallas, TX
    4,052
    Re: Question about CYA
    Those numbers tell me you are most likely using an unreliable method of measuring CYA.
    CYA does occasionally go away over the winter, or even more rarely when you have a major algae problem. It can also go away if you are doing water replacement for some reason.
    These numbers are coming from the pool store. They use a computer system to test the water. I did not replace ANY water or add any water during this time. I did have a bad algae problem I was dealing with and had to use LOTS of chlorine to deal with it. Used granular to start but the switched to liquid because it was easier. I am back to using my 3" tabs in my chlorinator and I will retest the CYA in a week to see if I need to add stabilizer. I just think its odd that it dropped like that when I keep reading that it never goes away...
    Cleveland, Ohio
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by LisaM
    That is your answer. They are notoriously inconsistent.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    What John said...always trust yourself...get a good test kit...like the TF100 and go to it. If someone tried to tell me my numbers were wrong I would laugh in their face. because of TFP I have gotten to the point I can look at my water and know whether things are good or not. Get a test kit that has the FAS-DPD test, pH, Total Alkalinity, CYA and Calcium hardness...Read the instructions and trust in yourself.
    TFP will not steer you wrong!
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    30,431
    Robbie and John have it pegged. Anyone would think the "Pool Store" would be the expert place to go but, sadly, it is frequently the opposite.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Excuse me for being the skeptic, but from reading many threads about pool stores and also dealing with a VERY dishonest PB, perhaps the store has a computer built to make the CYA go down. After the readings come out, the suggestion is to buy 10 lbs of CYA. Now think about it. The cost of the CYA is probably getting close to the cost of the TFT100 test kit. Buy the test kit and the next time you have to go to the pool store, you can tell them exactly what and how much you need. For kicks, you can have them test your water. The smarter you get, the less costly it becomes.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by XsAllOverIt
    When I walk into my pool store...they don't even bum rush me anymore...they know I am only there to buy liquid chlorine and nothing else...two cases less than $21 bucks that is $2.63 a bottle of 12.5 percent chlorine. They really don't like it when I tell the person who just walked up to the counter with $180 worth of chemicals that they don't need all of that. I have been politely asked to leave!
    Beave
    WOW you guys have encountered some really dishonest pool stores. I guess I am lucky. I have never encountered this type of thing. In fact they did not even suggest I buy CYA after that low reading. They actually are pretty conservative but it is a small mom and pop type store not a big chain so maybe that is why.
    Cleveland, Ohio
    Feb 2008
    Northwest Indiana
    902
    Actually my pool store has been great. I go to The Great Escape by my home. They have been great about the pool equipment. On day 2 my pump exploded...they gave me a brand new one no questions asked...The ladder system they sold me was supposed to meet all area codes. It did not...they gave me the ladder that met code (which was $100 more) for nothing. They have even at times just given me the little plastic C clips that hold the pump basket to the pump for nothing as well. I am always breaking those litte things. But they don't know much about pool care, Which I think is a problem.
    Beave
