Results 1 to 9 of 9
Thread: Dichlor
    Tresmer's Avatar
    May 2011
    College Station, TX
    3
    Dichlor
    Good morning. I'm on day 3 of owning a pool for the first time. I am following the "Beginners Guide for Seasonal/Temporary Pools" http://www.troublefreepool.com/pool-...ary_pool_guide found in Pool School. I have just one question at the moment, and that is concerning "Dichlor". I found what I think I need at Lowe's but the active ingredient is "Sodium dichloro-s-triazinetrione 15%", Is that the same as "dichloro-s-triazinetrione"? I couldn't find anything without the "Sodium". Am I good using this as my "pool shock"? Thanks in advance!
    6,423 gal. 18' x 48" INTEX AG
    stock pump and filter
    Re: Dichlor
    That is dichlor, however it appears to only be 15% dichlor, which is a very low percentage.
    Feb 2008
    Denton, TX
    5,061
    Re: Dichlor
    Yes, anything with "dichlor" in it is the stuff. I agree with JasonLion though; that is a very weak formulation. I don't think that I have ever run across 15% dichlor before. Got some last week from Kroger which was 99%.
    Tresmer's Avatar
    May 2011
    College Station, TX
    3
    Re: Dichlor
    Thanks for the replies. So the recommendation of "add one ounce of dichlor for every 500 gallons of water" in step 5 of Beginners Guide for Seasonal/Temporary Pools. Does that assume a 99% dichlor? Should I increase it to 6 or 7 ounces per 500 gallons since my Dichlor is only 15% ?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Dichlor
    Yes, it assumes 99% Dichlor, but I wouldn't add your product without knowing what else is in the product. If it were something like copper, it could end up staining your pool. If it were possible for you to take back the chemical, you should do that, but normally pool stores don't take back chemicals even if unopened.
    Tresmer's Avatar
    May 2011
    College Station, TX
    3
    Re: Dichlor
    I was trying to avoid the pool store, but after several trips to various box stores and grocery stores the best I could find was 15% Dichlor. I was out of town yesterday and passed by a Leslie's so I bought 5 lbs of 99% Dichlor. I started with that last night and added 1 lb. and left the pump running over night. This morning I've got FC 15ppm and CYA test has the water (in the test tube) slightly cloudy, but the dot is still visible with the tube completely full, but that's greater than zero, so it's coming up. Is it safe to swim at FC 15ppm and CYA barely above zero and pH 7.5?
    Feb 2008
    Denton, TX
    5,061
    Re: Dichlor
    Good to hear that progress is being made.
    I don't try to all out avoid the pool store. Sometimes, they really are the best place to purchase things. I just don't take their advice.
    Feb 2008
    Denton, TX
    5,061
    Re: Dichlor
    We don't advocate swimming in pool water that has a FC above shock level for a given CYA. But, that doesn't mean that people always adhere to these recommendations. Some still swim anyway and somehow, they almost always live to tell about it.
    Re: Dichlor
    Hey Tresmer, I would recommend you pick up some Fiber Clear from Leslie's ($13.49 sale right now) as well. This stuff really helps to filter out all the small stuff the intex filters can't. I have only been using it for a day now and the results are amazing. Good luck with your pool!
    Intex 15x48 metal frame 4,400 gallon AG. Dual stock pump setup using Filbur (A) filters.
