Thread: water leaking in connecting tube from pump to filter
    I'm trying to open the pool for the year..I just bought a salt free system but the connection from the salt water system to the filter is leaking. The connection is a threaded connection inside on the filter and outside threaded going to the salt water system. I have tried taping it several times and have made sure the fitting were tight. It is still leaking just a little and I have tried five times reseating and re-taping the connectors. Any other ideas? Thank you in advance
    22,548
    Re: water leaking in connecting tube from pump to filter
    It'll help if you can post a picture of the leak. Pipe paste for plastic pipes is probably better at sealing a leak than t-tape is. I'd try that next.
    Thanks alot I will try that next.
