Thread: pH question
    Jul 2009
    Upstate New York
    36
    pH question
    Pool chemistry:
    FC: 10
    TA 75
    pH: 7.1
    CYA: 0 (added the requisite amount of CYA to get to 80 ppm, waiting to test it again)
    Borates: 40
    Now, I have to raise the pH, right? I'll probably test it again later today when the FC will be lower (just finished superchlorinating). But to do that I have to add borax right? Is adding the 125 oz it will take to raise my pH going to have that much effect on my borate level? Now, isn't it a problem if I keep adding borax over time since borates don't degrade? Thanks.
    20,000 gal oval IG, vinyl liner. 1 HP Pentair Superflo pump. Intellichlor ic20 SWCG with easy touch, Sand Dollar SD80 sand filter, Taylor K-2006 test kit.
    Re: pH question
    Yes, you should raise your PH a little.
    Using borax does raise the borate level, but it raises it so slowly that you will never accumulate a significant borate level that way. The quantity of borax you need to use to raise the borate level significantly is huge, 15 or 16 boxes of borax, and before you get anywhere near that you will be losing borax through splash out, and backwashing.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: pH question
    You can also just simply aereate the water to raise your PH.
    Jul 2009
    Upstate New York
    36
    Re: pH question
    I always wondered how you aerate your pool. It's not like I have a couple of fountains I can turn on and off
    So, on the Pool Calculator, it asks your TA and borate level as well as your pH starting point. Why would the amount of borax change based on varying TA and borate levels?
    Re: pH question
    TA and borates both buffer PH changes, the higher the TA and/or borate levels, the more acid/base you need to add to the water to get the PH to change.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: pH question
    Quote Originally Posted by hyperchord24
    I always wondered how you aerate your pool. It's not like I have a couple of fountains I can turn on and off :)
    If you have eyeball returns, you can point them upwards with the pump on high to create surface disturbance of the water. That's what I usually do in my pool when I want to aerate. Of course, you could make something like this!
