Thread: tell me if i am right or wrong
    i am installing a new liner this year. (j-hook). any good tips on that would be helpful!!!!
    when my pool is filled should i adjust the alk. first, PH second and chlorine third?
    are there any other chemical i should add at the beginning as well
    sorry guys. i got a lil rusty over the past winter.
    24' X 52" round above ground pool---13,500 gallons---Hayward power flow matrix 1.5 hp pump---Hayward 21 in. variflow XL sandfilter---Louisville, Ky
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Re: tell me if i am right or wrong
    pH first.
    Then Chlorine.
    Get some stabilizer in there.
    Then fine tune. http://www.troublefreepool.com/pool-...ary_pool_guide
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ditto to what Richard said...except the temp pool guide. I know our lil 24's may not be top of the line, but I wouldn;t go ahead and consider them temporary.
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you test your fill water first.
    You're done SLAMing when:
    im thinking when i fill my pool up im gonna go get the water tested. get my CYA to 50 first. then im gonna adjust the alkalinity so my ph doesnt go crazy. then when my Alk. is stabalized i will stabalize my ph. the add some bleach. does that sound right. sorry guy got a lot goin on in my life right now.
    30,413
    Quote Originally Posted by rsharp
    As suggested above, please adjust your pH first. Don't worry about alkalinity. When your life settles in, grab yourself a big hunk of Pool School!
