Results 1 to 8 of 8
Thread: Cloudy Water
    Cloudy Water
    I need some help. My water had been fine and all the sudden it is cloudy. Having a party on Friday for my daughter and desperately need to clear the water.
    Clorine 4.5
    PH 7.2
    TA 230
    Vinyl pool
    What should I do? I know Borax will raise PH, but I also need to lower TA........
    Renee
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy Water
    What are CC, CYA & CH test results?
    Your pH is within range and I would not adjust it.
    You're done SLAMing when:
    Re: Cloudy Water
    CC is 4.5
    I don't test CH because I have a viny pool
    CYA is below 20 I have added stablizer to my skimmer in a sock on Saturday.
    Don
    SW Florida
    Pentair SWG
    Feb 2008
    Denton, TX
    5,061
    Re: Cloudy Water
    If your CC is greater than 0.5, then you need to shock your pool.
    Re: Cloudy Water
    Ok, I think I figured it out and tested correctly this time. I was confused. My FC is 4 my cc is 1.
    So what I don't understand is why to shock when I already have so much FC.
    Don
    SW Florida
    Pentair SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy Water
    Quote Originally Posted by reneec
    Off to Pool School for you Read the beginner articles and hop straight to "How to Shock Your Pool".
    I suggest you get started quickly to try to beat the party time!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Cloudy Water
    The CC is the waste product of chlorination and is an irritant. If you have 1 ppm of CC or more then you need to shock. If your water is cloudy as you say that is another indication that you need to shock. Use CYA/Chlorine Chart to find the shock level for your pool. The quicker you get the pool to shock level the quicker it will clear. Keep the pump running 24/7 and clean the filter when there is a 10 rise in pressure.
    Love TFP? Become a
    TFP Supporter!
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Cloudy Water
    When you have a CC value of greater than .5 it means you have stuff in your pool (algae) that is causing the water to be cloudy. In order to get rid of this stuff you need to bring the FC much higher than you normally would in order to kill of this stuff. Just having 4 ppm of chlorine in your case will not get rid of it. You have to bring the FC up to about 10 ppm and keep it there until the CC goes down below .5 and your water clears up and you pass what is called an overnight FC test. This is where you test the water FC level when the sun goes down and test the FC level again before the sun comes up. If the FC drop during that time is less than 1 you passed!
    So add more chlorine to get to 10 and check it every hour to start and keep it at 10. If you let it go down below 10 you may have to start the process over. Good Luck!
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
