Results 1 to 12 of 12
Thread: Particals In Water At Night ..... Why?
    Jun 2011
    Ofallon, MO
    11
    I run my filter 24 hrs a day, I estimate i turn my pool over about 4 times per day. My PDA says my salt level is 2600 ppm, currently i have my SCG at 50%. However i have only used test strips for checking levels.
    HACH Aquacheck 7 Strips
    Th 250
    Tc 2
    Fc 4
    pH 7.6
    Ta 100
    Ca 50
    These are the only test i have currently. Any time i take my water up for testing they always say it is perfect, and generally i dont have issues ever with water chemistry.
    My issue is from day one (3 years now) at night when i turn on the firber optic underwater lights i see millions of what looks like particals, almost a haze. During the day the water is absolutly clear. Also this season i have noticed more bubbles at the return jets and the slide when it is on.
    This year when i started the pool up i switched to a DE subsitute that claims it filters even smaller particals than DE.
    Jandy DE48 Filter
    Jandy Stealth 1.5 hp Pump
    Jandy Aquapure 14 Blade SCG
    Jandy PDA 8 Control & Power Center
    Raypak 399k BTU Heater
    20k Gal, Inground Fiberglass
    3' - 6' Depth, 38'X16' Rectangle
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Particals In Water At Night ..... Why?
    First off, I wouldn't use the strips - they just aren't reliable.
    FC + CC = TC so your TC can't be 2 if your FC is 4.
    I would turn off the SWG and make sure your FC is holding overnight.
    If the problem isn't related to your chlorine level, perhaps clean out the filter of the replacement stuff and try traditional DE and see if you notice any improvement.
    You can always see some particles at night using an underwater light, even with the very best filtering. They are there all the time, you just can't see them during the day. A DE filter, with DE or fiber, will get more of them out than other kinds of filters, but it will never get all of them.
    Jun 2011
    Ofallon, MO
    11
    Should I submit a pic
    Jandy DE48 Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    There will always be floaters in the water. Filtering is inexact - it's not like you suck all the water out into another tank then filter every drop of it before putting it back in the pool.
    Aside from the floaters you see in the light, is the water clear? Can you drop a dime in the deep end and see it from the deck? Can you tell if it's heads or tails? (The last part's a joke, by the way.)
    You may be developing sparklypoolitis.
    Jun 2011
    Ofallon, MO
    11
    At night? Fiber optic on or off?
    Jandy DE48 Filter
    Mar 2007
    San Rafael, CA USA
    12,082
    The pool should be clear so that you can easily see the drains in the deep end. Look at this picture of my pool during the day and this one at night where the drains and pool sweep are clearly visible even looking diagonally through the water from a distance. In fact, at night it should look almost as if there is no water in the pool except for the color tinge from the lights. Take a look at this thread for some photo examples of the expected clarity -- I have a post there that shows the floaters in front of the lamp (I have a cartridge filter).
    I see floaters in my pool in front of the lamp as well. And yes, if you have a pic then that can help.
    Jun 2011
    Ofallon, MO
    11
    I will get some pics tonight, I think I have more particles than yours shows. I can clearly see the deep.end floor at night. My pool does not have a main drain. I will toss a dime in tonight and take a pic.
    Jandy DE48 Filter
    Jun 2011
    Ofallon, MO
    11
    forgot my 8th grade daughter had the last day of school party so I had 25-35 kids in the pool for nearly 4 hours........FC went from 3 to under 1 with SCG running 100%!!! i will post tomorrow.
    Jandy DE48 Filter
    susa's Avatar
    Oct 2010
    Deep South
    578
    >> I run my filter 24 hrs a day...see millions of what looks like particals, almost a haze.
    what has helped me is to run the pump at superslow speed for 5 hours each day, in addition to ultraslow speed for 3 days / 24 hours / day. In ultraslow mode, I use below 90 watts of power and the water is absolutely clear with underwater lights on at night.
    Jun 2011
    Ofallon, MO
    11
    ok been out of town but i am back...... i am going to get a test kit i know that TFP like two kits but has anyone used the ColorQ Pro 7 or 11 kits?
    Jandy DE48 Filter
    Jun 2011
    Ofallon, MO
    11
    never mid just read a thread on the topic, i will get the drop kit 1st. FYI just found my backyard is in the St Louis Home Magazine
    Jandy DE48 Filter
