Thread: My Water test PH good, CYA low and TA high
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Here are my results from tonight, 6/1
    FC 3
    PH 7.6
    TA 230
    CH 250
    CYA 40
    Salt 2700
    SWG at 35% using 2- 40K cells.
    Wednesday 5/25, I added 20lbs of Cyanuaric Acid to skimmer, sucked up into filter.
    Had to add water sunday to bring water up to proper level (hope I found my small leak, in wall ladders?) appears that water has not dropped.
    How do I keep the PH in check but lower the TA? What am I missing??
    Test results from last Friday 5/27
    FC 1
    PH 7.1
    TA 200
    CH 200
    CYA 30
    Salt 2900
    Test results from Sunday 5/29 before adding water
    FC 5
    PH 7.2
    TA 200
    CH 220
    CYA 52
    Salt 2900
    Thanks
    Rich
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    Re: My Water test PH good, CYA low and TA high
    Read the article in Pool School on how to lower TA.
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Jasonlion,
    Yeah I read about lowering TA and use muriatic acid to keep PH in ck and know that it is the only way to lower TA, but it will bring my PH to 6.6 or lower which I perfer not to do, I can run my blowers for aeration to raise PH. Was not sure if their was another way, I could do this over a few weeks time so PH is not too low and not killing the CYA with adding too much muriatic acid if that is possible? I never have scaling problems with my SWG cells. Just being OCD with pool water.
    Do you think I need to get the CYA up? currently at 40. I have a safety cover on most of the day but like to open for a few hrs each day (weather permitting). I have no issues with water quality ( water is crystal clear can see screws for main drains which is 11' 6" deep )
    Thanks for your help
    Rich
    Saint Charles, IL
    Feb 2008
    Denton, TX
    5,061
    TA is lowered by acid additions, followed by aeration. Nobody is asking you to lower your pH below 7.2. You aerate to allow your pH to rise, then lower it back down to 7.2, aerate some more, and continue repeating the process until the TA is where you want it to be.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    It's just as easy as .257 Weathery Magnum says.
    Use the Pool Calculator to get the acid dose to drop pH to 7. Do whatever you can to aerate the water - run the spa spillway, turn on jets, slide, waterfalls, point the returns up, build a custome aerator out of PVC, folks have even connected a submersible pump to a lawn sprinkler in the pool. pH will go back up. Add acid to get it back to 7. Repeat. When you get TA where you want, stop the process.
    CYA is easy to fix. Add more. Are you sure you want to? Do you get a lot of sun? Do you plan to leave town for a vacation at all this summer? That's a good time to use pucks in a floater, which will add CYA. So you may want to keep it at 40, so you have a little breathing room to do that.
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Richard320,
    Will handle the TA decrease. I agree with the CYA, I really dont think it is too low now and would like to just leave alone for now. The pool is in direct sunlight from sun up to 1:30 ish then half of the pool has direct sun till 6:00ish, The safety cover is on while were at work and open most of the weekend if we are using it or home other wise it's closed for safety. Before a party of high swim load I will trun up the SWG and get FC to 6-8 then after a day brig it back down to 3. Never have had an issue with water quality or clarity.
    Thanks
    Rich
    Saint Charles, IL
