Results 1 to 14 of 14
Thread: Invention idea...need feedback
    May 2011
    Montgomery, TX
    176
    a plastic cylinder about the size of 10 pucks stacked ontop of each other. this clear cylinder would hold liquid chlorine and be inserted into existing rainbow erosion feeders to slowly introduce liquid chlorine into your pool. the bottom of the cylinder would have a very thick kind of mesh that would allow the bleach or chlorine to come out only when it was hit with a stream of water. if it worked of course you could always add onto it and make it bigger to hold more liquid. kinda like a rigged liquidator to utilize your rainbow feeder.
    whatchall think, would it work?
    Re: Invention idea...need feedback
    It could work in theory, but there is no easy way to regulate the rate at which chlorine mixes with the pool water. There are a number of products that take various approaches to regulating the rate chlorine is added to the pool, and the ones that work well tend to be a fair bit more complex than what you describe.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd say, a very fine thread needle valve at the bottom, and a large piston with a spring behind it. Then you'd have to have, say, 10 psi, to overcome the spring and start pressing on the liquid, forcing it out the needle valve.
    A simpler, more marketable solution would be something that fits exactly in place of a rainbow feeder and adapts it to a liquidator. No cutting, no gluing.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I want to invent a CYA neutralizing agent myself.
    May 2011
    Montgomery, TX
    176
    Quote Originally Posted by woodyp
    i know, there has got to be a chemist out there that can figure this out. he'd be a millionaire.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    It's probably been invented, but the pool chemical industry has most likely paid the person off. With a chemical that could neutralize CYA, pool stores wouldn't be able to make as much $$$ selling people "shock" when their pools turn green from inadequate FC levels for their super high CYA caused by trichlor and dichlor.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Quote Originally Posted by brg88tx
    I find that H2O at added at 500,000 ppm causes my CYA to drop by half.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    There is a chemical that will do it, but it's not being marketed anymore. It was expensive and didn't sell well.
    I noticed during my last screw up when I used citric acid for the metal staining....my CYA dropped by 50% from 60 ppm to 30 ppm.
    But it may have been a combination of things...I added HTH super algae guard..mistakenly thinking I was using polyquat....so it may have been a combination of the chemicals in the HTH super algae guard with the addition of citric acid.
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    Mar 2007
    San Rafael, CA USA
    12,082
    If you can reproduce this effect consistently, you'll have a great procedure. I don't see how it works, but I'm open to it anyway. Keeping fingers crossed...
    I'll be ordering CYA reagent when I get it I will try to duplicate conditions in 5 gallon bucket and see if there is someting to it.
    Mar 2007
    Coastalish 'down easter'
    4,160
    If the feeder had ever held trichlor, you're looking at a potential disaster! You simply can not mix different forms of chlorine in a feeder!
    Luv& Luk
    -Ted
    I have been told that the chemical used to test the CYA will neutralize it. Cost is about $40 gallon...
    Yes, it will also turn your pool into a white cloudy mess, just as it does to the water in the view tube of the CYA test.
