Results 1 to 10 of 10
Thread: Air coming through return
    When we first turn on the filter air bubbles come out of the return. It stops within a few minutes. Is this normal?
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Air coming through return
    Maybe. Does your pump basket stay full? Any significant height difference between the top of the water and the pump?
    I will have to check and see if the pump basket stays full when the filter is not on? I will look tomorrow. Should it stay full? The pump is higher than the top of the water.
    Thanks!
    East TN
    Raypak Gas Heater
    Ottawa, ON, Canada
    153
    It should stay full, maybe you've got a minor leak (I'd say check the multiport valve to see if it's sending water down the backwash hose)
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    30,403
    If air is getting in the system (and it is), the leak is on the suction side.....somewhere between the impeller of the pump and the skimmer.
    It is likely (but not always) that your pump strainer basket will have air in it when you check this AM but confirm that and we'll go from there.
    May 2009
    Topeka, KS
    81
    I'm having the same problem... My fear is a line cracked over the winter. As soon as i shut off the pump the basket at the pump drains down some.
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    I checked when the filter is off and the water in the pump basket drops even with the incoming pipe. The pump is at a higher level than the pool. We were wondering if the water flows back toward the pool when the filter is off. When I turn it on, it just takes a few seconds for it to fill up. Is that still a problem?
    Thanks!
    East TN
    Raypak Gas Heater
    22,542
    You're getting air in the system and it's getting in the filter and when you shut the pump off the air in the filter is most likely pushing the water back out of the pump basket.
    There are some common place's to check. The pump basket lid; inspect, clean, & lube it. The skimmer; make sure it's not creating a vortex, check weir for proper operation and not sticking. Pump basket drain plug; make sure it's not leaking.
    If those things don't fix the problem then run water from a hose over the suction plumbing while the pump's running and see if the bubbles go away.
    Thank you so much!! I will check all of those possibilities. I have a difficult time removing the lid from the pump basket. I usually have to get a rubber mallet to get the lid to turn. Is there a way to relieve the pressure before opening the pump basket lid?
    I have been a pool owner for less than 2 years and I have so much to learn. I really appreciate all of the help I get in this forum.
    East TN
    Raypak Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd also check for air trapped in the filter. It will compress when the pump is running, and expand again when the pressure is off.
    It's super easy to check. Just slowly open the air bleed on top the filter while the pump is running. If it hisses a bit before water starts shooting out, there's air. If water comes out immediately, it's ruled out.
