Thread: New pool owner, pool store woes, want to start the BBB.
    Jun 2011
    Columbus, Ohio
    17
    New pool owner 14x28 in ground shallow end is 3ft deep end around 6 ft. I have spent a ton of money on chemicals over the last few weeks trying to get my levels in order. A week after the pool opened I took my water in for testing - the cyanuric acid was 150 and all my numbers were somewhat off. Another $50 spent and out the door I go - immediately I started researching this site and ordered the k-2006 test kit (which hasn't arrived yet). The pool company told me I had a 10k gallon pool but using the online calcs it shows me having a 13,200 gallon pool. I wonder if all of my numbers were so blatantly off because of the pool store testing my water as a 10k gallon?
    Either way when I get my test kit I want to start using the BBB so I can save money. At this rate I will be spending $100 + a month just to hopefully keep the pool in check.
    I have read through some of the information here but was wondering should I just post my numbers and seek advice on how to get started, or should I use some type of conversion method to get started?
    14x28 inground rectangle vinyl lined pool 3ft on shallow 6ft on deep end.
    Taylor k2006 test kit.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New pool owner, pool store woes, want to start the BBB.
    Welcome to TFP...once you get the kit, post up the results and we'll get you going. IF, cya is really 150, you may have to replace roughly 50% of your water or perhaps Reverse osmosis is avail in your area?
    Jun 2011
    Columbus, Ohio
    17
    Quote Originally Posted by dmanb2b
    I replaced probably 10% of the water the best I could do. I ordered a longer backwash hose and plan to run it down the hill. Going to just drop my vac hose into the deep end/skimmer so I can pump as much out as possible. Again, I dont know if the cya level is off because of the testing or it is really that high..
    Thanks again my wife is stressing about the tons of money this pool is costing us already - as new home owners this is very frustrating as we love the pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Ordering a good test is the best thing you can do to put you in control of your pool. Good for you!
    You may want to slow down on the water replacement until you confirm the CYA level.
    Welcome to TFP
    You're done SLAMing when:
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    I have a 14 x 28 inground pool too. The Pool calculator says it is 14,700 gallons but the dig sheet said it is 10,963 and the pool store said it is 15,000 gallons. I'm going with what the Pool Calculator says. I recently got the Taylor K-2006 test kit and have been doing test the last couple of days. I am fighting to get the PH down. Yesterday it was 8.0 ppm and this evening it is 7.8 ppm.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Sep 2009
    Greentown, IN
    914
    Keep working at it and post your full test results when you get a chance. People here are great helpers and would love to see you get your pool running smoothly and inexpensively!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
