Results 1 to 8 of 8
Thread: Recent sediment at the bottom of pool
    Oct 2007
    Jacksonville, FL
    22
    For the past three days sediment been collecting at the bottom of my pool. I vacuum to filter but the next evening it re-appears.
    Test results:
    PH 7.4
    CL 3.0
    CH 450
    CYA 50
    ALK 60
    Salt 3900
    Borate 50
    Here are a few pics
    I'm not sure if this is relevent but I recently added a box of Borax and a quart of sequestrant.
    Does anyone know why this sediment has suddenly been appearing?
    Thanks
    21K - marcite - inground - Autopilot 48 SWG - 240 sq ft Pentair filter - 2hp 2sp Pentair pump - solar heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Recent sediment at the bottom of pool
    Probably just not being caught by the filter. Sneak some pantyhose over your skimmer basket and see if it helps.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Looks like pollen or dust to me
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Me too.
    30,432
    With that screen over your pool, I suspect the "sediment" is not coming from outside your pool but from within........i.e. algae.
    Absolutely the quickest and cheapest identifier is to carefully retrieve some from the pool floor and "roll" it between your thumb and forefinger. Is it gritty like dirt or slimy like algae?
    Let's try that test first and then figure it our from your post back.
    11,969
    If it is perhaps algae, and Overnight FC Loss Test would rule out organics too...
    Oct 2014
    Bloomingdale
    164
    Very good advice on all parts. having same exact re-occurring issue with sediment every season. Have put nylons over skimmer basket on top of skimmer sock. Didn't think to put nylons over return jet while vacuuming. Will try that if my powerful x stream 1.5 hp motor doesn't blow a hole right through it.
    Apr 2014
    Mobile, Alabama
    75
    I have the same stuff in my pool. I'm thinking it's either pollen, dust, or some manner of silt. The only way I've ever been able to get rid of it is to vacuum to waste, but eventually it'll reappear. It doesn't feel like anything to the touch because once you touch it, it dissipates into the water. At least that's what mine does. I've used filter clothes over my skimmer basket, but nothing stops it unfortunately. Maybe one day I'll figure out a way to get rid of it. Until then I just kinda live with it.
    Kevin T
    16' x 32' Vinyl Liner Grecian Pool. 20,000 Gallons. Sta-Rite SuperMax 1HP Pump (PHK2RA6E-102L). W. Cooper Ranger Series 25" Sand Filter. Dolphin Nautilus Plus.
