Results 1 to 9 of 9
Thread: Trichlor tabs
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Trichlor tabs
    I'm in the proscess of building up my CYA which is at "0" right now. I'm wondering about the use of trichlor tabs and their stability in the short run. will the CYA in them stabilize the FC now? Or does that take time as well?
    Thank you,
    Ed
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Re: Trichlor tabs
    Trichlor can certainly be used when your CYA is 0, but they will add CYA very slowly. They also add FC slowly as well, so either use liquid bleach and some stabilizer, or dichlor granules for quicker results. Can you post a full set of test numbers so we know what you are starting with, and also as many pool specs as you can?
    Re: Trichlor tabs
    Welcome to TFP!
    The simple answer is: no they will not stabilize the chlorine until the CYA level builds up a little. That's really what RobbieH said, just in different words.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Re: Trichlor tabs
    Yes Robbie:
    FC 3.0
    CC 0
    CYA 0
    TA 150 (oops)
    Ph 7.3
    Vinyl above ground pool 10,000 gallons, Haywood 40 DE filter. Everything looks great but the FC is disappearing so fast.
    10,800 gallons
    TF-100 Test Kit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Trichlor tabs
    2lbs of stabilizer should get your CYA to 20 and then the tabs may be able to keep up for a while. Just keep and eye on CYA and if it climbs to 50 or above, switch to liquid chlorine.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Re: Trichlor tabs
    I have one pound in the water now that I added Saturday. I figure it's not registering to be tested yet.
    10,800 gallons
    TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Trichlor tabs
    Quote Originally Posted by Whatrymes
    It can take up to a week for the CYA to show up in testing. Don't waste your reagents testing too soon.
    ETA: btw, I would not do anything about the TA unless you have future problems with the pH rising. Looks good now
    Welcome to the forum
    You're done SLAMing when:
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Re: Trichlor tabs
    Welcome to TFP!
    So using bleach is no less stable that tabs for maintaining FC levels? I have been enjoying using bleach and its more predictable results.
    10,800 gallons
    TF-100 Test Kit
    Re: Trichlor tabs
    Correct. The only real difference is that trichlor does several things at once, add chlorine, add CYA, and lower PH, while bleach just adds chlorine. Adding only one thing at a time gives you more flexibility and more control.
