Thread: Well Water Analysis
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    Well Water Analysis
    Long time lurker but this is my first post. Signed a contract on a pool with Anthony & Sylvan and should begin excavation on Monday. I will attempt to attach a pdf of my well water analysis for you review. Is this water compatible for a pool or should I go with the city water? Thanks for your responses... I'm sure more concerns and questions will follow.
    [attachment=0:3vvrsiay]Well_Water_Analysis.pdf[/attachment:3vvrsiay]
    Greenhaw
    Attached Files Attached Files
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Well Water Analysis
    The calcium levels are a bit high. If you can get city water with low calcium levels and just use well water for topping off it will be easier for you to manage.
    Love TFP? Become a
    TFP Supporter!
    22,549
    That water looks good. Very little metals. Unless I'm reading it wrong, calcium is only 221 ppm which is the middle of the road for plaster & fiberglass pools.
    Green1340's Avatar
    May 2011
    55
    Thanks for the responses. The calcium level is 221 ppm and I thought those were in line for a plaster pool. The high/ low levels indicated on the tests are the water's suitability for irrigation of plants and build up in the soil. (I use this water for turf and garden irrigation.) I thought the metal content was acceptable @.01 and .02 ppm- these were the levels that I was really concerned about.
    Greenhaw
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Calcium is fine, but the TA looks sky-high (if I'm reading it correctly). Bicarbonate = 488 = TA of 488?
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, I would agree that the TA looks high to me assuming the bicarbonate measurement is in the TA standard of ppm CaCO3. If it's not and is ppm bicarbonate, then the TA is 400 ppm, but that's still high. It just means you'll be adding a lot of acid to get it down lower in order to avoid more frequent pH rise over time.
    As for the calcium, this depends again on how they are measuring the ppm. If this 221.2 is ppm CaCO3 then that is fine, but if this is in calcium ppm, then the equivalent CH is 553 ppm which is on the high side, especially with the high TA.
    You really need to find out if they are using standardized ppm units or if the ppm are of the specific component they are listing -- especially for calcium. Is this calcium ppm or equivalent calcium carbonate ppm?
