Thread: CYA/SWG question
    CYA/SWG question
    Just tested my water today and CYA was about 90-100 using the TF100 kit..From reading pool school, levels should be 80 for a SWP..Should I be worried about the elevated levels ? my FC is at 8ppm, ph 7.3, TA 80..Thanks!
    24X52 AG..Hayward DE 1HP pump..Intellichlor IC15
    Re: CYA/SWG question
    As long as you are sure that CYA is under 100, you can get by with your CYA level where it is. The thing to watch out for is that CYA levels above 100 will read as if they were 100, so you might actually have a higher CYA level. One way to double check this is to do the CYA test again, but this time mix equal parts of pool water and tap water together, do the CYA test on that, and multiply the result by two. As long as you get about 100 that way, you will be alright and can wait for the CYA level to come down on it's own.
    Thanks Jason..I actually tried that but I didnt get any reading that way..filled the tube all the way up
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    That doesn't make sense.... You should have seen some cloudiness. You didn't, by chance, forget to add the R-0013, did you? I made that mistake once.
    The sample should be 25% pool water, 25% tap water, and 50% R-0013.
    Quote Originally Posted by Richard320
    Darn your right!! LOL I forgot the R0013 Just retested and got a read of 45..kinda overcast outside
