Results 1 to 7 of 7
Thread: Its in the mid 90's today!!!
    Mar 2011
    North Carolina
    34
    Hey all,
    Its in the mid 90's today, and I am curious while in the clean up stage how much will this blistering heat take from my Chlorine reading , compared to a normal day when the water is crystal clear???
    Foxx Pool Grecian 27000 gallons (vinyl liner)
    Sand Filter w/ 300 #'s of Brand New Sand 6/3/11
    Re: Its in the mid 90's today!!!
    You will certainly use more chlorine than usual, but it might only be a little bit more. Chlorine usage goes up with the water temperature, and water temperature rises more slowly than air temperature.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    My water temp hit 86 today!
    Apr 2011
    Somewhere on the Emerald Coast
    156
    Are you using stabilizer (trichlor / dichlor)?
    Is the pool shaded or in direct sunlight?
    What is the status of your "clean up stage"? Are you dealing with a swamp or just normal spring opening?
    We hit 97 today and my water temp is still only 81 !!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    my chlorine consumption is getting higher with the higher temps. I was getting about 8-10 PPM with my SWG set at 10% running 24 hrs. I tested yesterday and I'm now at a comfortable 4.5 ppm
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    22,542
    I wish it was the mid 90's here it hit 103º yesterday. Here's hoping it's only the mid 90's today!
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Aug 2010
    Dallas, TX
    4,052
    We are going to be around 99 today. It is only June!!!
