Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: A retreat from Texas heat: nutjob's pool
    nutjob's Avatar
    May 2011
    Dallas
    109
    Here are the pictures from the construction of my own pool project. Thanks to Southernwind for making it possible.
    The full gallery is also available.
    Select Shots
    The plan: we had a third-acre lot, but an enormous storm drain easement running through. That limited the size of the pool—and also helped us stay within our budget:
    No messing around with Bobcats:
    Fine-tuning the excavation:
    Rebar'd; the pipes sticking upward are part of the A&A QuikClean system:
    Shotcrete application:
    Future swim-up bar:
    Equipment pad (see the full gallery for more detailed "equipment pr0n"):
    Opened up the panel to see if I could fit my own automation add-ons in there (plenty of room):
    Stone finish (and a bored daughter) in the sunken kitchen:
    Pebble finish:
    Curving steps out of the sunken kitchen to completed deck:
    Filled & running & nearly complete—save for some weather delays:
    Fire+water wok burning fire and pouring water:
    Negative-edge spa:
    Rainfall scupper behind the swim-up bar:
    Grotto, fire+water wok, and the… comfy chair:
    We've been heating it since late March (and had some shockingly high gas bills) but those have fallen to reasonable levels recently—likely thanks to the black pebble finish. It's 33ºC (92ºF) right now outside, and the water has climbed to 30ºC (86ºF) on its own. The swim-up bar is a fun diversion, however most of the cocktails I've mixed up have been for the under 12 year old crowd. The rainfall scupper is mostly useless, as the slightest breeze will send its water into the sunken kitchen (there is a sump pump). It was a neat idea, though.
    Our contractor was quite responsive until the very end—getting odds and ends finished up took weeks (and months in some cases). We'd probably use them again, but will withhold the final 10% (or more) of payment until absolutely everything's done.
    That's it!
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: A retreat from Texas heat: nutjob's pool
    Nutjob, nice pool! Love the water color! That's the only drawback to dark color,HEAT!
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Aug 2010
    Dallas, TX
    4,052
    that's a friggin' cool setup!
    So, I was having this discussion on another thread, I'm curious to know how much it drove up your bill to fire up the heater. Obviously it would cost me more since I am dang near 3 times the size, but I was told between a grand and 1200 a month to run my pool heater for very little gain!!
    My white plaster pool is sitting at 84 right now, heater has never been turned on. We will be resurfacing soon, wife wants the same color you have, I'm worried about bath water temps.
    Apr 2010
    Buckeye, AZ 85326
    619
    The fire/water bowls are really cool. To bad about the water blowing into the kitchen. Have you heard of rain chains? You might be able to modify that rainfall maker a bit and get some use out of it using the rain chains. Very nice build!
    EDIT
    Can you get a pic from the balcony with full sun hitting the pool? Just like the one with the snow only when its sunny. Thanks
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    nutjob's Avatar
    May 2011
    Dallas
    109
    Thanks folks! Appreciated! ^_^
    Well RobbieH this is a smaller pool certainly, but here are my gas bills this year (and last year, pre-pool, for reference):
    • March 2011 $568.05 (March 2010 was $108.98)[/*:m:1nes29lf]
    • April 2011 $486.68 (April 2010 was $71.34)[/*:m:1nes29lf]
    • May 2011 $29.11 (!!) (May 2010 was $33.90)[/*:m:1nes29lf]
    Of course, it was a nasty cold winter too. The pool's thermostat is set for 28ºC (82ºF). Still, I'm surprised at the drop in the bill from April to May. If I may quote the esteemed maxepr1, HEAT!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Holy S$%T! Nutjob, you quit playing with those fire bowls! I take it the spa is not a closed loop from the pool? This fall I think I would try a cover and maybe a wetsuit!
    Aug 2010
    Dallas, TX
    4,052
    OK, that somewhat confirms what I've been told. Thanks for the info, I think I'm going to take my heater out and sell it!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Robbie, just remember the darker you go the warmer the water is! You may also want to look into cooling towers also. I'm going to buy/make some this year. Tired of 90' water in July!
    nutjob's Avatar
    May 2011
    Dallas
    109
    Quote Originally Posted by maxepr1
    HAHA!
    Right. A pair of 3-way actuator valves switch the drains and returns between "pool mode" and "spa mode".
    Pool mode: main drain open, spa drain closed, floor-cleaner & skimmers on, spa jets off.
    Spa mode: main drain closed, spa drain open, floor-cleaner & skimmers off, spa jets on.
    There's also "spillway" mode: main drain open, spa drain closed, floor-cleaner & skimmers off, spa jets on—allegedly to make a pleasing bubbling sound as water percolates down the walls of the spa into the pool. I can't hear it over the traffic noise, though.
    Wetsuit . . . yeah, good thinking!
    However, I would really love to see your cooling towers once you get going on them!
    Aug 2010
    Dallas, TX
    4,052
    Our water was bath water last year. I don't know how warm because we had just bought the house and there was no thermometer. I want very light material, and I'm going to win this battle! Diamond Brite is on our list of materials to look at, I would love to see pics of yours!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Robbie, if you look under my user name I have posted the pool pictures. I am going to post some new ones this week hopefully now that I'm Borated! We went with DB blue/black quartz, looks good but we should have went darker! I built the pool DEEP (11ft) so the water would warm slower but by july I will be in the mid 90's! Cooling towers going in as soon as beta testing is done! Nutjob, think gas was high wait till you see electric!!!!! Hopefully that pump will help!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,607
    We don't need no heaters in Texas
    Aug 2010
    Dallas, TX
    4,052
    Agreed! MIne is indoors in a room right behind my garage. If I get rid of that heater (and sell the copper out of it!) I have room to move my 80 gallon compressor out of the garage!
    Apr 2009
    Burlington, ON, Canada
    344
    That's a drawback??!! Gawd, I envy you people who live where it's hot year round.
    Nice pool/outdoor living area!!!
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Aug 2010
    Dallas, TX
    4,052
    RCY, you might reconsider when you realize it can easily be 106 degrees here, and the pool water can be well into the 90s. If you lived here in the 80s, you'll remember several days in the 110+ range and pools so hot people were throwing blocks of ice in (it didn't help!)
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    rcy, when it's 105' out and you decide to cool yourself off in your beautiful refreshing pool , bring a bar of soap!! The waters 98' ! No Joy!
    nutjob's Avatar
    May 2011
    Dallas
    109
    Quote Originally Posted by Shane1
    No prob! Here goes:
    Looking south:
    Looking west:
    Taken around 4.45pm local time, so not totally full sun. I'll try again tomorrow.
    Thanks also for recommending rain chains. I had never heard of them before, but a little googling and I've seen the light!
    Apr 2010
    Buckeye, AZ 85326
    619
    Thanks for the pics. I like that color and set up a lot. Hopefully the rain chains work or at least give you some ideas for something else.
    2' Powerfall
    Butterfly's Avatar
    South Carolina
    10,045
    nutjob, when can we come over?
    I absolutely love fire bowls and waterfalls. Everything is just gorgeous!
    There was a pic of a future Miss America in there somewhere, too!
    You're done SLAMing when:
  20. Back To Top    #20
    Apr 2009
    344
    Quote Originally Posted by RobbieH
    Send me some heat and I'll send you some cold...lol.
