Results 1 to 17 of 17
Thread: Generic bleach vs. Clorox bleach
    Can somebody please tell me if generic bleach like wal mart or dollar general,which has 6% on the bottle,is the same as Clorox bleach. A lot of money to pay if they're all the same strength. Thanks for all help.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Aug 2010
    Dallas, TX
    4,052
    Re: Generic bleach vs. Clorox bleach
    Yep. Same stuff. You got the key component, make sure it's 6%. Unscented, no extra **** added.
    There are some very minor differences. Clorox is a little more careful to make sure they are always full strength, while some of the discount brands vary a little more, but they are almost always close enough that it is not a big deal. There are also occasional reports that some obscure discount brand is raising the PH more than it should, but that is rare.
    Jun 2010
    Toms River, NJ
    80
    I personally have used walmart brand last year and so far this year with good results. I have also seen others use it with the same success.
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    Butterfly's Avatar
    South Carolina
    10,045
    Lots of members use the Walmart bleach and, lots use Aldi's bleach. Both have had good results.
    Now, as has been said, you gotta' be careful w/the dollar stores, super-duper discount stores, etc. Either the bleach can be old and weak or simply started out weak to begin with. No joy.
    You're done SLAMing when:
    JeepGirl's Avatar
    May 2011
    South of Peoria, Central IL
    52
    I checked our local Deals store and Big Lots today. Found a bargain brand at Deals for 1.00 per 96 oz bottle of ultra bleach, but nowhere on the label did it have percentages. So I stayed away from it, and bought 96 oz bottles of White Cloud premium bleach that said 6% for 1.50 a bottle. Is that a good practice to not buy it if it doesn't list the %??
    ~Shell
    24' AG 13,500 gallons
    Hayward pump, sand filter
    Deck yet to be put up...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,680
    Quote Originally Posted by JeepGirl
    YES!
    You're a fast learner!
    I happened to look at a bottle of Simply Value brand bleach my wife has out in the garage for laundry... 2.75%. I doubt it was a value at all.....
    Apr 2011
    Somewhere on the Emerald Coast
    156
    You might want to check out your local ACE Hardware - I get the stronger 10% for slighltly more per gal than the walmart 6% ($1.77 vs $1.99). And - NO - I do NOT work for ACE - even though I've promoted them here. It's just that they have a better deal (IMHO) on chlorine than walmart or the pool stores around here.
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Apr 2009
    FT WORTH,TEXAS
    2
    aldi bleach .99 goog stuff been using it for 2 seasons now
    24 X 52 AG ,WATER WAYS FILTER CART. ,2HP 2 SPEED PUMP
    May 2011
    lebanon tn
    370
    usually use walmart brand, but occasionally wife gets an off brand- she's a couponer, so finds stuff all the time!
    She knows to only get 6% or better- some other people (Canadians, I think) even noted some major brands selling 4%!
    That's 2/3 (66%) the chlorine, at 75% cost, so actually losing money to achieve same amount in pool!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    In my area (Eastern PA), WalMart is selling their 96oz bottles of store brand bleach (6%) at $1.27. Interestingly per ounce, the 96 oz bottles come out cheaper than the larger bottles - go figure! More bottles to carry, but much easier to use - especially since I often find myself needing to add 1 or 2 entire bottles - no measuring! I used it exclusively last summer with great results.
    But I checked out Aldi's the other day and found their 6% generic brand for only $0.99. I stocked up and will be trying this brand this summer.
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Quote Originally Posted by madwil
    More work too, since you have to buy, add and move more volume of bleach to achieve the same FC levels.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Sep 2009
    Greentown, IN
    914
    Sometimes the smaller bottles are cheaper per ounce than the larger these days... for everything. Seems companies have trained us that larger is the better value and then turned around and shifted the prices on us. I always check now before I buy anything.
    Kind of like how Walmart started out being so much cheaper for everything, now.. I rarely shop there because they aren't cheaper.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Last year I had some issues with Walmart bleach, maybe it was the pool consuming more chlorine than usual. I did not keep good enough records to be sure. Problems went away when I went back to Clorox it seemed. Maybe it was a heat problem with high summer temps, I dunno.
    Make sure to check the label.
    The Clorox Bleach here is 5.5% and the No Name stuff at the same store is 4%
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Mar 2010
    Spring, TX
    1,082
    I have tried off brands and they do not seem to work as well as Clorox. So I stick with that. I can get 3 182 oz jugs at sams club for under 8.00. Works out to be a good deal.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    May 2017
    Temecula, CA
    74
    WHat about Cloralen from Walmart?
    33,000 gal IG plaster 38x18, chlorine,with spa spillover to pool, built 1999, 4 Cartridge filter, Nat Gas Heater, 100% in sun all day-TK-2006 and Speedstir
