Results 1 to 7 of 7
Thread: vinyl pool and CH=80. Pool store said add calcium....
    or we will risk scale build-up on our SWG device. However, I've read on TFT that calcium is not a concern with vinyl pools. I bought the 15 lb tub of calcium but don't know if I should add it (i.e. listen to the pool store guy) or ignore and take it back. What do you recommend? Thanks so much!!
    In-ground pool owner in NW Georgia: 18 x 37 IG Grecian vinyl pool installed April 2011: 27k gallons, Hayward SWG auto-cleaner with booster pump, Hayward Aquarite T-15 Salt System with timer freeze controls, Hayward Aqua Plus, 1.5 HP Tri-Star pump, 48 sq. ft. D.E. filter.
    Re: vinyl pool and CH=80. Pool store said add calcium....
    That is actually quite funny. Adding calcium is the only way you could possibly get scale on the SWG. Right now there is no chance of scaling, but if you add calcium there would be some chance of scaling.
    There is no reason to add CH, except perhaps if your warranty coverage requires it.
    Thank you so much, Jason. That's what I had thought from reading TFT over the past two months but I'm such a newbie that I question everything. I will have husband return the calcium tomorrow and get our $30 back. Geesh.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    What he said
    How would you get calcium scaling with a lack of calcium
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    If they offer you store credit instead of a refund, use it for something safe: a volleyball set, some swim fins, a new brush head. No chemicals. That salesman is either incredibly stupid or icredibly dishonest. Either way, not to be trusted. And don't let them sell you a steel brush head for your vinyl pool!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I personally keep some reasonable level of CH in my vinyl pool as I don't want to worry about splash out puddles eroding the concrete floor over the long term.
    Ike
    Quote Originally Posted by Isaac-1
    That is not an issue. If it was concrete would be destroyed by rain, which has extremely low CH levels.
