Thread: Hydrostream Eyes
    Hydrostream Eyes
    Can someone tell me where the directinal hydrosteam eyes are suppose to be moved to. I have one at the deep end that is a few feet off center and the step area has another one which in on the side of the pool near the low end. I thought they are just suppose to ripple the top of the water but i want to check. I think they should take it from the one in the deep end to face closer to the same side as the step one for things to go around and then go around the pool to get to the skimmer. Any info will be appreciated.
    15x30 In ground vinyl liner, 16000 gallons. Sta-Rite Sys 3 Cartridge Filter (S7M120), Aqua Comfort Heat Pump Model 110, Sta-Rite Max-E-Pro 1.5HP 2 Speed Pump (Model P6RA6YF-206L), Loop Loc Mesh Winter Cover and always use Solar Cover. Polaris 9300 Sport Cleaner, Taylor K-2006 Test Kit.
    Liquid Super Chlor 12% (Sodium hypochlorite)
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Hydrostream Eyes
    Not sure there is a right or wrong way to point them but I have all point in a counterclockwise direction. So there is a little bit of current in the pool. I have a few potential dead spots so that's the reason for the CC direction.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Does someone have an answer.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Can you post a pic or diagram of the pool, the skimmer(s) & return locations? (you can hand draw a diagram of the pool and take a pic of that and post it [thanks Casey ])
    Luv& Luk
    -Ted
    Here is the photo. I've circled the skimmer in red and the two eyes are circled in yellow. I realize the direction would go from the far end to the stair area and around the pool to hit the skimmer but I'd like to know if they should be pointed towards the bottom of the pool or just have them barely break the top etc.[attachment=0:2iucjnw6]Zpooleyes.jpg[/attachment:2iucjnw6]
    Mar 2007
    4,160
    Given your set-up, have the return ion the deep end wall point 'straight' out (water ripples ~ 5' out) and the stair return point ~ 45* towards the stair edge and slightly down.
    You have the MDs to help circulate the bottom water, so use the return to make any floating debris get to the skimmer.
    Luv& Luk
    -Ted
