Thread: borates ?
    Whidster's Avatar
    Mar 2011
    Camas, WA
    68
    borates ?
    When we were doing baquacil we added Endure, a borate to the pool. We did not drain when we did our conversion. I have some older borate test strips and it reads that I still have a borate reading of 50.
    Can I assume that the borate level is fairly accurate. From what I understand the only way to get rid of borates is to drain and add water, so the conversion should not have eliminated them from our water.
    What do you think?
    20,000 Gallon Vinyl Splash AG pool. Goldline SWG. Two sand filters w. 1.5HP Sgl Spd pumps. Lexan Aqua Shield dome. Solar heating, with propane back-up.
    Camas, WA
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: borates ?
    I think that sounds reasonable.
