Results 1 to 8 of 8
Thread: Increase CYA?
    Increase CYA?
    Trying to decide if I should shock or increase the CYA? I'm using about 182oz+ of 6% bleach nightly. I've done a overnight FC twice. The first night 1.0 decrease second night no decrease. Water is clear. Been hot pollen is just about gone but has been heavy and I've been catching with skimmer socks. My pool is in direct sun all day. Last year my CYA was at 80 and know i used less bleach to keep FC up. Is there something I'm missing? Add bleach at night to bring up to 6.0 next night 1.5 - 2.0 with some swimmers through out the day heat and direct sun. What do you all suggest? I don't think i need to shock???
    FC-2-6
    CC 0 - .5
    PH 7.5
    TA 70
    CH 100
    CYA 30
    Thanks
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: Increase CYA?
    No indications of needing to shock there as far as I can see. When I get down to 25, I use some pucks to chlorinate and bring CYA up gradually. 40 seems to work for me.
    30,427
    Re: Increase CYA?
    Yeah 30 is too low for the sun and bather load you're placing on the pool. I would bring it up to 50ppm.
    Re: Increase CYA?
    I have an old floater from last year should I use that for a couple days or go the solid in the sock route in front of the jets? thanks
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: Increase CYA?
    Socks in front of the jets will be a whole lot faster. The jump from 30 to 50 pretty much requires it.
    You could shoot for just below 50 and use a puck or two at the same time, just a thought. I think you have options but getting to 50 rapidly would not be an option for pucks alone.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Increase CYA?
    I suggest the granular in the sock.
    You're done SLAMing when:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: Increase CYA?
    I use a gallon of bleach a day at CYA of 50ish with full sun pool as a yard stick for ya'. Your pool is twice my volume. Considering going to 70 myself. Losing right about 4ppm per day as is.
    Re: Increase CYA?
    I had CYA of 80 last year seemed to work good until you needed to shock at closing. Will see what happens at 50 for now and then make that decision. Thanks for the input
    Central, VA
