Thread: multiport repair ?
    multiport repair ?
    recently was given a Hayward sandfilter setup with a 1hp pump but the multiport (Vari-Flo XL Valve SP-0714T) but the port is stuck in filter
    mode, hard to turn, won't backwash... is it easy enough to replace gasket's oring's and such or would it be simpler to shell out the 75.00 at amazon
    and buy a new one. thanks for any help
    easy set 18x48 intex 2100 sand filter or hayward sand filter w/1 hp pump
    22,539
    Re: multiport repair ?
    It's easy and relatively cheap to replace the o-rings and gasket in the multiport. Just remove the screws, Pull the top off and take it with you to the pool store, or order them online.
