Thread: Intex Pool - Leaky Seam
    Hey folks, first time poster, short time reader.
    I've done a couple of searches of this site and haven't come up with an answer, so I thought I'd ask.
    I have an Intex Pop-Up (Soup Bowl) pool, 15X48. This is the second season we've used it. Being extremely foolish, I tried to winterize it last winter. (It was fine until the four foot snowdrift ate it alive.)
    So, after much cleaning out, I now have two problems:
    1.) The ring isn't holding air very well. I figure the soapy-water and contact paper trick should work here. That, or two minutes with the pump a day. (That's two minutes of my life I was going to waste on TV anyway, so be it.)
    2.) The main seam between the ring and the liner seems to be leaking. See, I filled it up as usual, ran the filter, everything looked aces. Woke up the next morning and six inches of water was missing. I checked the pump jacks (which has been leaking) and fixed them. Thinking the problem was solved, I filled again. Within fifteen minutes, sheets of water were flowing down the sides of the pool. Within two hours, it has stopped and the water was sitting just below the seam. Logic tells me I have a leaky seam.
    So ... how do I fix this? I'm thinking of buying a can of Flex Seal and simply spraying the whole seam area all the way around. Anyone every used this or a similar product for such a repair?
    Thanks in advance.
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo Variable Speed 3HP, Pentair Clean and Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Intex Pool - Leaky Seam
    Welcome to TFP!
    I'm not sure how you could fix the seam but I do know how you can find the hole(s) in the ring. It is very hard to see air coming out of the ring through the hole even if you use soapy water so try this idea.
    Make sure the ring is dry and fill the ring with water. As the inside of the ring fills up with water the ring will leak just like the seam does. You will then know exactly where the hole(s) are and patch them. Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Thanks Mark. I'm beginning to think I might be better off just getting a traditional vinyl patch kit and running it around the seam.
    As for the ring, the water suggestion is a good one. I just worry about getting said water out.
    May 2011
    lebanon tn
    370
    if the seam tear is small, you can patch it pretty easy. waterbed patches work if you can't find a pool patch kit.
    don't know about flex seal...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    The fact that it's an "As Seen on TV Product" has me rethinking the Flex Seal ...
