Results 1 to 10 of 10
Thread: new home owner first pool
    my water has a white foam on top what is this from
    Aug 2010
    Dallas, TX
    4,052
    Re: new home owner first pool
    Going to need more information than what you've provided. Pool type, filter type, salt water or no, chlorine type to sanitize, and a full set of test numbers. Pictures wouldn't hurt any either.
    22,553
    Also, what ever you've added to it in the last few days?
    i have a sand filter and the poolis above ground 18 round i use 3 inch chlorine tablets i dont have the numbers with me im at work i put in pool shock 32oz algacide and cholrine
    Some of the common algaecides will cause foaming. If that is the problem then you just have to wait it out, up to about a week before the foam goes away completely.
    22,553
    Some algaecides cause foaming. I bet that's your problem.
    In order to have a Trouble Free Pool you need: 1) A good test kit of your own, 2) To read Pool School, 3) To read Pool School.
    when should i vacum it
    22,553
    You can vacuum it whenever you want or need to. It's not going to affect the foaming either way.
    Thanks for all the help I will have more questions
