Thread: Help!! Odor (like chlorine) smell that makes you cough
    We have an outdoor/in-ground pool, chlorine based and experience the coughing anytime splashing takes place, which is almost all of the time.
    This started last season, the third since the pool was built. I believe it is the CYA (150 reading) and dont know how to lower it besides draining 50% of the volume. Suggestions? other readings are: FC 1.5 CC 3, hardness 100. I've owned inground pools for almost 15 years and never had this puzzling problem.
    -MrRic
    23000g IG Vinyl
    Hayward SP-125-JS
    Jacuzzi MFM24 Sand Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help!! Odor (like chlorine) smell that makes you cough
    Hi - I split off your post to form your own topic.
    IF your CYA is 150 then yes, you need to lower the level through water replacement. Otherwise if Reverse Osmosis is in your area you can try that. Your CC is 3 that is certainly part of the problem.
    You need to get down into the 50-70 range for your CYA to be able to properly shock the pool. Do you have your own test kit?
    Welcome to TFP!
    The coughing is from the CC. To remove the CC you need to shock the pool, which is going to be very difficult to do correctly unless you bring the CYA level down dramatically.
    Butterfly's Avatar
    South Carolina
    10,045
    Your CYA may indeed be higher than 150 as most tests loose accuracy around 100.
    Water replacement or RO.
    Welcome to the forum
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    It seems to be unanimous!
    It would be helpful knowing a little more about you and your pool. If you're in SoCal or Phoenix, we know that R/O is available, and can tell you who to call.
