Thread: SoftSwim A & Borates, do I need both????
    I was wondering since I am using SoftSwim & Borates in my pool, do I still need to be adding SoftSwim A??? If the Borates prevent all algae from growing, what would be the point in adding an Algacide as well?
    Thank you for your time & efforts!
    Type: Doughboy 16x32 Oval Above Ground w/ 7' Deep End
    Volume: 17,500 gallons
    Chemicals:SoftSwim, Borax & Acid
    Testing Method: Colorq Biguanide Pool/Spa 5
    TA:135
    Ph:7.9
    Biguanide (SoftSwim B):35ppm
    Biguanide Shock (SoftSwim C): 49ppm
    Borate: 90ppm
    Feb 2008
    Denton, TX
    5,061
    Re: SoftSwim A & Borates, do I need both????
    No need to. As long as you keep a proper amount of FC in your pool, algae will never be a problem.
    Quote Originally Posted by 257WbyMag
    My pool is a Biguanide (SoftSwim) pool not Chlorine, so I don't have FC.
    TA:135
    Ph:7.9
    Borate: 90ppm
    Borates do not prevent all algae from growing. They slow the algae down a great deal, but don't stop it completely. So yes, you still need SoftSwim A.
    Thank you very much for your time & information!!!
    TA:135
    Ph:7.9
    Borate: 90ppm
