Thread: Viking vs Water World FiberGlass Pool
    Hi All
    I am thinking about putting in a fiber glass pool
    So far these two manufactures have contacted me. Which One is better?
    Also who is considered to make the best fiber glass pool
    Thanks All
    Paul
    Batavia, IL
    28
    Re: Viking vs Water World FiberGlass Pool
    Read the warranties carefully and be sure whoever installs it stand behind their work. I have a customer with brand "x" (big reputable company) fiberglass pool installed by a company that is no longer around. The pool developed a crack in the bottom (likely an install issue). It was cheaper for me to repair it underwater than have the mfg repair it under warranty. Basically the homeowner was responsible for pumping ground water (hope your installer put the drainage system in correctly), drain the pool, brace the pool while empty, keep dry so the mfg could do a repair. To add insult to injury, the warranty explicitly says the repair does not have to match the existing get coat.
    20 x 45 Inground vinyl, ~34,500 gallons,
    4 returns, 2 skimmers, dual main drain
    Pentair EasyTouch 4, IC40 SWG, MiniMaxNT 400, TR100 sand filter,
    Whisperflo .34/2 hp 2 speed, Polaris 280 w/ polaris booster pump,
    Wild ride slide, InterFab techni spring base w/ 8' InterFab olympian board
    APC 365 dark gray auto cover
    Dec 2010
    Central California
    15
    I looked at both Viking and Leisure fiberglass pools.
    Talking to installer's for both was enlightening. In the end I decided the installer was more important than the manufacturer (warranties being similar).
    My family has been enjoying our new pool this summer...and I'm enjoying the benefits of a fiberglass pool. It's early, but I'm definitely satisfied with my decision to go fiberglass
    30'x14' (12.5K Gallon) Viking Carmel - Saphire Blue Crystite Finish
    Jandy Stealth Pump - 2 Speed 1.0 HP
    Jandy Cartridge Filter - 340 sq. ft.
    Fiberstars 6004 Metal Halide Light with 4-Position Color Wheel
    Polaris 280
    Maintained with BBB
