Results 1 to 7 of 7
Thread: First test results of the year - Bromine pool
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Okay here is my first test results for this year -
    Keep in mind this is a bromine pool,
    Bromine - .5
    Ph - 7.6
    TA - 120
    CYA - 10
    TDS - 450
    After testing the water I added 4lbs of sodium bromide to help build my "bank" back up after starting up the pool. I have two floaters filled with bromine to help bring the bromine levels up. I will re-test again tomorrow and see if the bromide has helped with the bromine levels.
    Any thoughts or suggestions on these levels would be appreciated!
    I plan on doing the borax/muriatic acid this week unless there is some reason I should wait.
    25,000 gal. bromine, IG plaster pool w/sand filter, 2 spd, 1hp, 1.5fr sta-rite pump.
    Re: First test results of the year - Bromine pool
    I'd add some chlorine to bring the bromine level up to normal levels more quickly.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    I will add more chlorine. I've added some off and on for the past two weeks but I will put more in tonight and test again tomorrow.
    Thanks!
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    I just added my last to gallons of bleach. I'll have to go for a bleach run to re-stock tomorrow. I'll re-test and post results tomorrow.
    Are the other levels at an acceptable level?
    Yes everything else is good. The PH is perfect, TA a tiny bit high but acceptable, CYA and TDS don't matter.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    I accidentally posted this in one of my other threads. So here is my re-post.
    Today's updated test results -
    Bromine - 3.4
    pH - 7.6
    Alkalinity - 130
    Hardness - 200
    So the added bromide and bleach yesterday seemed to help bring my bromine levels up to normal range. Should I assume my bromide "bank" is up to where it needs to be?
    Now that my levels are in the normal range should I be able to maintain my levels with a bromine floater and chlorine when needed?
    Thanks again to all who have helped! I can see this season will be much more successful than last season!
