Results 1 to 11 of 11
Thread: Chlorine Confusing Me
    Jul 2008
    Seacoast, NH
    250
    3 weeks ago we opened the pool. The water was cloudy, the Chlorine was 0, the CYA was close to zero, the pH was <6.9. I spent a week shocking the pool and getting the other factors balanced. The water cleared up, but there was still a little (<0.5) CC so I kept the FC > 10 for quite a while (2 weeks). This is our 4th summer and the CC is almost always 0 and that was where I was trying to get.
    Since the CC wasn't going above 0.5 and the water is finally warm enough for swimming, I turned the SWG down last night. It was a nice sunny day so I thought the FC would drop. Well, it did. But the CC went up. Here are my numbers
    FC = 4.5
    CC = 2.5
    pH = 7.5
    TA = 80
    CYA = 60
    Salt = 3090
    Yesterday FC was 10 and CC was <0.5.
    Any advice? Do I have an algae problem? The water really is crystal clear.
    Thanks.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Feb 2008
    Denton, TX
    5,061
    Re: Chlorine Confusing Me
    I would say that you have some sort of organic in the water (algae maybe) that is consuming FC. You need to shock, and 10 ppm on the FC is not high enough. Your CYA being 60 means that you need to raise the FC up to 24 to shock, keep it there until the shocking is done. Turn your SWCG off during this process and use bleach. It saves wear on the cell.
    Algae or not, shocking the pool ought to take care of it.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    With CC at 2.5, you are not done shocking or now have the need to shock again. Were you able to pass the overnight FC loss test before you stopped the previous shock cycle? Any dead wildlife hiding in the plumbing?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Bring that puppy up to shock level until that CC number is .5 or less. Did you do the overnite FC loss test when you were shocking?
    Jul 2008
    Seacoast, NH
    250
    Yes, I did do the overnight test and it passed.
    1.5 HP Pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Other than a dead mouse or something, any kids that may have had a bathroom accident?
    Jul 2008
    Seacoast, NH
    250
    No, no kids have been in the pool. No one has been in it besides my husband and me.
    1.5 HP Pump
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Deb04
    Did you remember to turn off the SWG when you did the overnight test?
    ....just asking to rule out....
    You're done SLAMing when:
    Jul 2008
    Seacoast, NH
    250
    Actually, I cant be 100% sure now that I did turn off the SWG for the overnight test. I think I did, but maybe not.
    So, I've had the Chlorine at 24 for about 24 hours now and the CC is down to less than 0.5. The water is cloudy and there is a bunch of grayish silt like stuff on the bottom. My husband vacuumed it up about 4 hours ago and there is some more now.
    Theories
    Should I have the fiter still on? The SWG is off. Going to do an overnight test tonight.
    1.5 HP Pump
    Aug 2010
    Dallas, TX
    4,052
    Run the pump 24/7 for a while. The gray means you DID have organics still.
