Thread: Ring around the Main Drain
    Bucks Count PA
    73
    Since the pool was opened this season there has been a ring/ stain around the main drain. I have scrubed it with a brush from outside the pool and vaccuumed and the stain is still there. There was a lot of dead worms around the main drain when I opened the pool this year so I assume that it is from them laying around the drain all winter.
    What can I try to use to get rid of the stain?
    Inground Grecian 20,000 gallons vinyl liner
    Hayward 250 BTU Propane heater
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What kind of pool surface do you have? Organic stains normally fade away with chlorine. Shocking will often fade them dramatically.
    Bucks Count PA
    73
    Sorry it is a vinyl liner.
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    mbar's Avatar
    Ashland PA
    257
    You can try a magic eraser by Mr. Clean, sometimes it is just needs a little scrub You can also put some crushed vitamin C tablets in a sock and rub it on the stain, if it comes off, then it is a mineral stain. You can also use some ph down in a sock and rub the stain. Ph down and vitamin C will take off a metal stain. Organic stains come off with chlorine.
    16x33 fiberglass pool sand filter
    Bucks Count PA
    73
    I tried the Mr Clean eraser this weekend and it did nothing. The stain has gotten a little bit lighter. I am going to try the Vitamin c and see what happens.
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
