Results 1 to 15 of 15
Thread: 1st time BBB with new pool finish
    Ok so I delt with my problems of yesteryear and basically had to get my pool resurfaced. I went with pebble sheen, water has been in the pool for about 6 days. After the pool company did my 1st chemicals I got readings of this (I have added no chemicals between readings)
    11500 gallons
    5/27
    FC 4ppm
    CC .5
    TC 4.5
    PH 7.2
    TA 110
    CYA 58
    5/31
    FC 0
    CC 0
    TC 0
    PH 8.2
    TA 110
    CYA 40
    I used the pool calculator and dumped in about 45oz of bleach and put some tabs in my floater. The pool calculator confuses me because it uses chemical names and not the BBB (3B's). The calc told me to ad 21oz of M/Acid, 72oz of bleach and 15oz of stabilizer. I would put in some 20 mule Borax but my PH is already high. Basically any help getting me started and reading the pool calculator would be awesome! thanks! Im using the big tf-100 fyi
    Cornerstone 18 x 36 Rectangle 22,000 gallons
    Hayward SS24T High Rate Pro Series Sand Filter
    Inground Vinyl Liner with Polymer Walls
    1.5hp 220 volt energy efficient High Performance Pump
    Intermatic swimming pool Timer TR104P3
    Aqua Genie Skimmer System (2)
    Hayward Color Logic light
    Liner: Oxford aquarius 28 MILL
    Re: 1st time BBB with new pool finish
    Lower the PH to 7.2 with muriatic acid, and don't add any more borax for the foreseeable future. Every time PH goes above 7.8, lower it back down to 7.2. That will probably means daily acid additions, though perhaps only every other day.
    The PH, TA, and CH levels are all going to go up fairly rapidly for the first three or four weeks and then more slowly for up to a year.
    You can keep using trichlor for a little longer, but very soon you are going to need to switch to using bleach because the CYA level is coming up fairly quickly.
    thanks for the quick reply Jason. So when should I use Borax? what kinda of levels would I see effected by the Borax? I will go add some M/acid right now persay the pool calculator. I want to use the BBB exclusively tho i put in the tabs today, I was just trying to get the TC up and level out.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Borax is optional. You can add it whenever, or never. But you don't want to start messing around with it until you get the rest of the numbers in range and relatively stable. It will just add one more variable you don't need right now.
    Right now you need to get pH under control and get some chlorine in that pool before it turns green. And watch that CYA- the only way to get rid of it if you add too much is by draining and refilling.
    Right now, the PH is going to be constantly going up. If the PH somehow gets too low, just wait an hour. In several weeks, when the PH increases slow down, borax will be useful if you need to raise the PH for some reason, but right now it just means adding more acid to get the PH back down.
    Ok so it sounds like right now i need to worry mostly about Chlorine and PH (checking cya and ta as well) as the pool water is fresh there is nothing built up in the water. As a result it is very volatile to swings in PH?
    today i was @
    FC 3
    CC .5
    TC 3.5
    PH 7.4
    TA 100
    CYA 40
    I added chem's at 4-430pm so we will see what the days son does to the pool that time today.
    Richard320's Avatar
    Jan 2010
    19,071
    Chlorine is right on the borderline. I would add a little more.
    Richard320, remember fresh plaster only a week ago. Not a big deal, but because of that it is alright to go a little easy on the chlorine, or raise it a little but not raise it a lot.
    The PH won't swing around much, it is just going to go up and up for a couple of weeks yet (aside from when you lower it with acid). Fresh plaster will always raise the PH rapidly for the first three or four weeks and more slowly for up to a year. This has nothing to do with the pool just being filled, it is because of the fresh plaster.
    Mar 2011
    Austin, TX
    9
    We resurfaced our pool about 3 months ago. PH rose daily for about the first 6-8 weeks. Now it seems to be very stable.
    13,500 gal IG 3'-5', BBB (less Borates), Hayward DE filter, 400k BTU Hayward heater, 2HP A.O. Smith pump, 2 skimmers, Sunstone Pearl "Aqua Blue" surface, Colorsplash 3G light, Blue Diamond cleaner, A.O. Smith 6' slide, K-2006 test kit
    Ok been checking everyday things seemed to be steady but today I have some funky readings inconsistent with my others.
    FC 5
    CC 5
    PH 7.2
    TA 70
    CYA 33
    is there anything I need to do to get my CYA up and TA? Ive only been adding bleach and acid as needed til this point, I do have a floater in the pool however (should i take this out?)
    Richard320's Avatar
    Jan 2010
    19,071
    The floater will add CYA, which isn't bad for now, as you can use a little bit more. But the pucks also drive pH down, as you can see. If you have a spa or waterfall, run the return water through them to aerate, that should get pH up. If you don't have those features, try aiming your return jets up. Or search "aerator" and look in the threads with paperclips next to the subject line, they'll have pictures of some clever homemade aerators.
    I have a aerator that sprinkles out into the pool, i can run that.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hello Taxidermist~~
    Congratulations on your new PebbleSheen.
    What test kit are you using? You have not mentioned a Calcium Hardness reading. Looking at your posts and seeing incremental CYA readings of 33 and 58, I'm guessing that your having your water tested at the pool store?
    You need a good test kit to take proper care of your pool!
    Also it can't hurt for you to visit PebbleTec.com and read what they have to say on the Service and Support page of their website.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    tf 100 its in the last line on my 1st post
    my CH is 250
