Results 1 to 10 of 10
Thread: New To Me Pool...What Do All These Pipes Do?
    Swamp Thing's Avatar
    Nov 2010
    Eastern WA
    25
    Hi all...New pool owner here with questions. I called City Hall today to see if there was any info on record of when my pool was built. Nope.
    Maybe someone here could help with some basics:
    House built in 79.
    Tagelus filter dated 2004.
    Gunite in-ground pool 16' X 40'-ish.
    Pump/Filter station.
    What does the little pipe that elbows and is plugged do?
    My skimmers (2) have 2 holes each and the holes furthest from the pool have suction to the filter...What do the other holes do?
    There is a plugged hole next to the ladder in the deep end...It seems to do nothing. At first when I removed it today there was some suction (Pump off) for about 30 sec. I turned the pump back on and nothing happened.
    My drain has no suction.
    There is a hole about 18" below the shallow end skimmer that is open and does nothing.
    In-ground Gunite 16' X 40'
    Tagelus TA/60 Sand Filter
    A.O. Smith 1 HP Motor
    Sta-Rite Dura-Glas II Pump
    Pentair #320 Inline Chlorinator
    Intermatic Mechanical Timer
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: New To Me Pool...What Do All These Pipes Do?
    Hi, from what I understand, the 2 hole skimmers may also be connected to the main drain. How you would switch to main drain I couldn't say. The hole under the skimmer also has to do with main drain function. The pipe to nowhere may have been a dedicated line for a booster pump at one time. It probably goes to the plugged hole by the ladder, which is where a cleaner would connect.
    As for your signature, witty comments are appreciated, but the main purpose is to list your pool stats and equipment in case we need the info to answer any future questions.
    Love TFP? Become a
    TFP Supporter!
    Apr 2010
    Buckeye, AZ 85326
    619
    Check out this old thread. It sounds like just the info you are looking for.
    what-are-the-two-holes-in-the-skimmer-t17573.html
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Dec 2010
    San Diego, CA
    1,137
    Are there any valves hidden in the landscaping around the pool? Or nearby to the equipment pad?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    I'm fairly sure that the opening below the lower skimmer is connected to the second hole in the lower skimmer, and the drain is connected to the second hole in the upper skimmer.
    The extra pipe very likely goes to the 1 1/2" threaded plug, and was used for a booster pump to power a pool cleaner.
    Nov 2010
    Eastern WA
    25
    Quote Originally Posted by zea3
    ...As for your signature, witty comments are appreciated, but the main purpose is to list your pool stats and equipment in case we need the info to answer any future questions.
    Fixed.
    Nov 2010
    Eastern WA
    25
    Quote Originally Posted by carlscan26
    No
    The pool came with 2 "Kreepy Kraulys". I tried one hooked to the skimmer inlet and it didn't work...Makes sense now.
    Maybe there was a booster at one time...Hence the closed wiring boxes next to the pipe.
    Here's the actual pool...I just discovered yesterday that I've been "recirculating" vs "Filtering" my pool for 3 weeks (no valve sticker). Don't you just love newbies.
    Hope to have it cleared up soon...Can't see the bottom.
    Dec 2010
    San Diego, CA
    1,137
    You might be able to get a suction cleaner like a kreepy krawly to work via a skimmer...probably the lower skimmer with the opening below it, but you'll need a diverter plate thingamajiggie and may also need to block off the other skimmer since you don't have a valve to control where the pump is drawing from.
    If you haven't already, then read up on shocking in pool school and it'll be sparkling in no time. You have a good test kit already right?
    Nov 2010
    Eastern WA
    25
    I got my KK to work last nite after posting my last response. Mine works via the skimmer and yes I had to block off the other skimmer...The KK is awesome. As for the "shocking" I think I did it right but I'll review...Still relying on the pool store 1 mile from me for the chemicals but I'll get a test kit son...Thanx!
    Dec 2010
    San Diego, CA
    1,137
    That's unfortunate they didn't setup valves to control this stuff. But you're getting it figured out! Definitely get a good test kit - check pool school for the recommended ones.
