Thread: Pressure Test Questions...Please help. Thanks.
    Apr 2011
    Oklahoma
    37
    I posted questions regarding pressure test but was wondering if I could get more opinions.
    We have shot the gunite on our pool and I noticed water around a skimmer. Did a pressure test and saw pressure was dropping, realized it was just a leak in the pipe which is blocking the suction (I think...line most "away" from pool when looking down into the skimmer). That was fixed. We ran the pressure up to 20psi with water and it dropped to 14 overnight. I can't "see" any water seeping through the concrete but.....
    I have 3 seep holes in the bottom of my pool that the gunite guys left. The one at the middle (deepest point) of our pool (sport or play pool) is holding a very small amount of water. The one on the west end is dry but the one on the east end has water. I shopvac it out and it immediatly comes back. This seep hole is higher than the middle one which only has a small amount of water. It is also closer to where the pipes all meet to begin their run back to my pad.
    I took the pressure off my pipes, shopvac the water out of the seep hole and now it appears the water level in my seep hole is going down. I'm convinced I have a leak.
    Anyone else have any ideas?
    34 x 19 salt water free form. 7.5" inside diameter raised spa. 24" raised beam in back. 3 moss rock waterfalls off raised beam and moss rock waterfall out of the spa. (2) Intelliflo VF pumps, 420 Cartridge Filter, 400 BTU Pentair low nox heater. 2.5" suction and 2" returns throughout.
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Re: Pressure Test Questions...Please help. Thanks.
    Is there a shrader valve and a water spigot at the manifold? You can use a spray bottle with a mixture of dishwashing soap and water to check for leaks. Spray it on all of your threaded connections. It'll start to bubble if it leaks.
    I went through the same thing during my pool build. The PB was confident that it wasn't leaking but it was, both at the skimmer and at the schrader valve. The schrader valver still leaked after I tightened it. So I bought a new valve and lubed it with magic lube and that stopped the leak.
    My other leak at the threaded joint of the U-3 skimmer was from a pressure test kit made for the U-3. I was made of a couple of plugs and a hose connected between the two. It had a break in it that I was able to fix with epoxy.
    Here's a couple of links to about it. You can find one here
    and another one here
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Seep holes in the bottom of the pool and leaks in the plumbing almost certainly don't have anything to do with each other. It would take a major leak to produce enough water to get to the seep holes, while it is common for natural ground water to come up through the seep holes (that is what they are there for). Losing only a few psi overnight is a very slow leak. A leak large enough to get water down to the seep holes would never hold pressure at all.
    Apr 2011
    Oklahoma
    37
    Thanks both of you....makes total sense.
    I will be reading those threads now...thanks again.
