Thread: lowering alkalinity
    lowering alkalinity
    when you go through the procedure to lower your alkalinity,after adding acid and waiting for ph to lower,is it necessary to stop aeration each time,or is it ok to let the aeration continue during the entire process. Thanks for the help.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: lowering alkalinity
    Keep aerating...the PH should drop within 30mins, if not perhaps the acid is not being mixed in well enough or you may not be adding enough acid to lower PH to 7?
