Results 1 to 8 of 8
Thread: NPool Quote - Is this a fair price???
    I would love some feedback on this pool quote. Seems pretty reasonable based on some other quotes I've received but it would be much appreciated to hear from some folks that have actually seen and done this before.
    Price $36,500
    Pool 12x26
    Spa 6x6
    Depth 3’6”-5’
    All Plans, Permits and Taxes
    Steel reinforced SHOTCRETE Pool Shell
    Three Shallow End Steps
    4x4' Swimout Bench in Deep End
    Waterline Tile: 6x6"
    Hayward Pump 2.5 HP
    Hayward Cartridge Filter
    Aqua-Rite Salt Chlorine Generator
    Savi LED Colored pool and Spa Lights
    NSF Approved PVC Plumbing
    2” Deck Drain Along House
    400K BTU Heater
    Full Size 6' Spa W/ 4 Therapy Jets, Raised 6" Above Deck
    Genuine PebbleTec / PebbleSheen Interior Finish
    Footing for Enclosure
    Quick Kelan Max Cleaning System
    Channel Drain
    Leaf Basket
    Venturi Skimmer
    Remote Control System
    Shellock Decking and Coping
    Pool Start up and Chemicals
    Re: NPool Quote - Is this a fair price???
    That is a fairly good price most places. Prices do vary quite a bit from place to place however.
    If at all possible get a two speed pump, or if your electrical rates are above $0.20 per kwh get a variable speed pump.
    Hmmmm....so would the recommendation be that if it is just "fairly good" it is likely we could better price from the company?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Where are you located? Prices in Florida are very inexpensive and you have quoted footings for enclosure. How much deck area are you getting and is it stamped concrete or pavers?
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    We am in Tampa. We are getting Shellock from Artistic Pavers for the decking. I'll have to look into the exact square footage of decking we are getting as part of the package. I mentioned the footers for the enclosures b/c we though it made sense to put it in now in case we wanted it in the future as they are fairly common in FL.
    Make sure you add in Elec and Gas work cost.
    21,500 Gunite Free Form ~ 18'X40', Sun Deck w/ foam jets auto valve, 3-Laminar Deck Jets w/ auto Valve, 1-Swim out, 3' to 8' deep, NPT Raku Tile
    All Sched 80 Pipe, Pentair Easy Touch control, Pentair pump and Sand Filter, Raypack Heater, White Plaster, Saline Chlorine Generation, Letro Platinum cleaner w/ booster
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Normally in the contract it states a specific size of deck. Nail down the cost if it exceeds that square footage so there is no suprise in cost when they tell you how much more per square foot it will be. Also make sure you have the removal of dirt costs defined in the contract so those additional costs come out as "by the way"...
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    That sounds about right. We are in Tarpon Springs and our quote for
    14x28 freeform 11,500gallon with 7' custom spa raised 18in, salt sytem, variable speed pump, infloor cleaning system, sunshelf with bubbler and travertine decking 500 sq ft plud redo anouther 450 sq ft of existing deck with travertine is $42,000
